Results 1 to 10 of 10
Thread: Coloring Your Pool Water question?????
    Jun 2010
    Tennessee
    138
    About 6 years ago I found a product on Ebay called "Party Pool". You mixed it with water and poured it in your pool to make the water Lagoon Blue. I added it for a Luau party I had. It did leave a blue residue at the water line for a while but eventually the chlorine washed it back off. Have any of your heard of or ever used it. Is it bad for the pool and does anyone no where to find it? I have searched and can't seem to find it anywhere?
    30' Round Vinyl AG, 21,200 K GAL. with Main drain, Hayward 1.5 HP Pump, Sand filter, BBB Method & TF~100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,790
    Re: Coloring Your Pool Water question?????
    I've never used it but here is a link to locate a dealer. You can also order from them online.
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    Tennessee
    138
    Thanks I found it.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I tried this stuff about a month ago. It did not seem to alter the water chemistry any, and the chlorine breaks it down in a few days. The only complaint I have is that it left blue stains just above the waterline on the tile of my spa. A magic eraser easily removed it.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Jun 2010
    Tennessee
    138
    Yeah it colored the water line on my pool too and eventually faded...but it sure looked pretty for my luau. I'm glad it didn't alter the water chemistry. I might get some more. Thanks
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    94
    I see that Party Pool also makes green. Would be fun to change the water color for a Jets football pool party (one of the advantages to South Florida - year-round swimming). Do we know how fast chlorine breaks up the color? Will having a high FC accelerate the process?
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Mar 2007
    San Rafael, CA USA
    12,082
    I used GLB® Party Blue® with similar results. It's an organic dye that will slowly break down with chlorine.
    Sep 2009
    Greentown, IN
    914
    We could all color the water green when we want the pool to ourselves. No one has to know it's not algae. If they don't have a pool they likely wouldn't know the difference
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,712
    Quote Originally Posted by HofstraJet
    Or to mess with your neighbors pool
    Factory Warranty Station for:
    chessie6's Avatar
    East Hartford, Connecticut
    187
    I bought Party Blue when I saw it recently at a Job Lots store and tried it out yesterday . . not impressed. I was so surprised to see my water turn sea green instead of the gorgeous blue I had expected. The good thing is that it was gone by morning. Higher chlorine levels do cause it to disappear quicker but I don't know what they mean by "higher levels" . . According to all the commercial info re pools the recommended range for chlorine is like 1, so maybe they consider my level of 6 to be high, but my CYA is 40-45.
    Anyway, I'll use up the bottle but I won't buy it again unless I knew it would tint my water blue instead of sea-green.
    Best,
    Jan
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
