Thread: Question About TA Test
    Hi everyone:
    New pool owner here and I'm trying to get a handle on my water chemistry. Last night I measured my TA with the TF-100 kit and I'm wondering about the instructions that say to add drops of the R0009 until it turns red. Does "red" really mean red? My solution turns to pink after 3 drops and gets a little darker with subsequent drops, but it never gets red, just dark pink. So do I stop adding drops when it first turns from green to pink, or keep adding until it really goes to red (not sure if it ever will).
    Thanks!
    Seattle Area
    18x36 Kidney Inground Vinyl
    Pentair VS 3050
    Pentair 420 Cartridge Filter
    Pentair Easy Touch
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Question About TA Test
    I'd say your TA is 30-40. It's like a magenta pink, not a true red.
    Baking soda...
    Use the Pool Calculator to help you figure out how much to raise the TA up to 70-80.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by grantorino
    Hi everyone:
    Thanks!
    It's pink, not red. And if you have a lot of chlorine in the water, the test goes from blue to yellow, not green to red. Add until it turns pink. Then add one more drop. If it gets a little deeperpink, that's the number. When adding drops no longer changes anything, you're done. Ignore the drop that did nothing.
    Perfect, speedy information, thanks! That would put my TA at about 40. I'll check out the pool calculator and buy some baking soda.
    I'm sure I'll have many more questions as I try to figure all this out, so thanks in advance!
    Seattle Area
    Pentair VS 3050
    Pentair Easy Touch
