Thread: almost catching prime
    Apr 2010
    Central NJ
    227
    I have a leak in my pump, which I bought the kit http://www.poolcenter.com/gokit3.jpg to hopefully replace.....well that's another issue, but thought you should know in case it's related to the problem below.
    Every night I have to prime the pump, and I'm noticing strange behavior which I cannot explain. I close all the returns except for my closest skimmer, fill up the pump basket and turn on the pump. All is working fine, and the pump reaches about 90-95% capacity and then it just loses prime. It doesn't start to lose it, it just loses it.
    If I do the same process with the main drain, it works fine (it just takes me longer). Once it gets primed, I can then open my skimmers without any problems. Can somebody explain why I lose prime with the closest skimmer. BTW, once the pump is working fine, the closest skimmer's suction is good.
    thanks
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    22,553
    Re: almost catching prime
    Sounds like the skimmer is sucking air when you're trying to prime the pump.
    Apr 2010
    Central NJ
    227
    but the water level is half-way up the skimmer which, from what I understand, is the correct level. Of course, I'm a newbie, so I could be wrong...probably am too.
    I guess I will try it again, with the skimmer cover off and see what's going on there.
    22,553
    Sometimes even with the water level half way the water will form a vortex when you're drawing a lot of water through it and suck air in. Sometimes it's caused by the weir sticking so check that as well.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by jrguzmanr
    That sounds like a good plan. Check that the weir on that skimmer (the flapper) isn't binding. If I hold the weir closed, I can empty my strainer and be sucking air in about 4 seconds!
    Apr 2010
    Central NJ
    227
    sounds like a plan!
    thanks
