Results 1 to 7 of 7
Thread: Cinder Block Walls?
    Jun 2010
    Rural Southern Illinois
    49
    Cinder Block Walls?
    I was looking into building my own inground pool, I really doubt that I will unless I buy land and build a new house, but you never know. Anyway, I seen several places showing people building the walls out of regular cinder blocks. I was just wondering if there was anyone on here that had any experience with this type of pool. At minimum I would like to have a 20' x 40' with 3.5-4' end for kids, with the other end sloping down to 8' or whatever is necessary to allow for diving from a diving board. Although, I would really like an L shaped pool to add an extra 20' x 10-20' to the shallow area. Thanks in advance for your knowledge!!!
    17100 gallon 27' Round 4' Deep Above Ground Pool
    Hayward Cartridge Filter 1 HP pump 50 GPM flow rate
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Cinder Block Walls?
    Duraleigh has such a pool, though it's a bit more complicated then just cinder blocks. His build thread is here.
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    That is a good choice Silver!
    Without knowing for sure do I think cinderblock is the most cost effective way to build a pool.
    If I should go that route myself would I choose 10" wide blocks and reinforcements in each shift.
    A figure I have heard for a cinderblock wall is that you need reinforcements every 20 feet. Nothing complicated or expensive to achive, so no worries there.
    Cinderblocks is a DIY project for sure. Buy yourself a cementmixer which you sell once you done. Besides for the mixer isn't there much tools you need. A couple of trowels and buckets and a good wheel barrow of course, masonry strings and a laser. Yeah a grinder so you can cut the rebars It's fun goes fast and turns out great
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    Oct 2009
    3,899
    I would consider buying a vinyl pool kit and installing it myself. If you have a high water table, building your own pool gets much more difficult, since the hole will constantly be filling with water.
    BTW, where in So. Illinois are you located? I went to high school in Carbondale.
    Jun 2010
    49
    Thanks for the opinions! Feel free to keep them coming.
    Melt, I grew up in Ava and now live in Steeleville. That's kinda funny you went to high school in Carbondale, small world as they say!!!
    Oct 2009
    3,899
    Silver, if you haven't seen Henry Porter's DIY build thread, it's here: http://www.troublefreepool.com/concr...th-t10055.html
    Lots of work, but really cool to watch the progress.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Silver, just to warn you, Mats(Henry Porter) is the king of rebar. So be prepared if and when you look at his build
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
