Results 1 to 7 of 7
Thread: Where to test?
    Jun 2010
    Rural Southern Illinois
    49
    Where to test?
    Where exactly in your pool should you test. As my sig says, I have 27' Round 4' deep pool, for reference I have 18 top rails. I have been taking the water for the test anywhere between right by the skimmer/return, to 1/3 to 1/2 way around the pool away from the skimmer/return. Thank you for your advice!!!
    17100 gallon 27' Round 4' Deep Above Ground Pool
    Hayward Cartridge Filter 1 HP pump 50 GPM flow rate
    Feb 2010
    Houston, TX
    271
    Re: Where to test?
    I test mine on the side opposite the skimmer and return. I just get the sample from there because it's closest to the back door! I think I remember reading that you shouldn't take a sample right at the return, but I'm not sure. Maybe someone else can clarify that part.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Jun 2010
    49
    Re: Where to test?
    Yeah, after I tested a few times, I started thinking by the skimmer/return wasn't the best place, but of course that is where the pool is closest to the back door for me!!!
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Where to test?
    I take my sample from the spot that gets the least amount of circulation. I figure, if there's anything wrong with the water balance, that spot will know it. As well, I take water from an elbow's length below the surface to get a more accurate FC reading because the water of the top however many inches may have had its FC destroyed by the sun.
    Consistency in collecting and testing is important. Wherever you get the water, take it from the same place and at pretty much the same time each day.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    22,553
    Re: Where to test?
    Anna has a good point about testing in the area with the least circulation. You should also test after the pump has been running at least an hour.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Where to test?
    I go about halfway down the side of the pool, where it starts to get deep. Then I squat down a little, cap my 4' piece of pipe with my thumb, and stick it way down in the water, aiming for the center of the pool. Remove thumb, let pipe fill, recap, lift, and release into my measuring cup. On occasion I may go to the far side and grab some from the deep end midway between returns to add to it. And if I still didn't fill the cup, I stop and get a sample from 2' down in the shallow end, to get a good blend. Especially if I'm feeling OCD that day.
    Jun 2010
    49
    Re: Where to test?
    I always take it from elbow deep. I guess halfway around the pool or maybe 2/3's of the way around would probably be the place with the least circulation.
