Thread: Testing kit
    Testing kit
    Hi,
    Can someone please tell me what the best ph testing kit is. I have a Taylor kit but can't match the colors for the life of me and wonder if ther might be a better solution.
    Southern California/sun all day
    26k gal/in-ground plaster/jacuzzi spillway
    dual speed 1.5/2.5 Hayward
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Wife in bikini and Margarita maker
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Testing kit
    Are you colorblind? If not, then maybe the test block has faded with age.
    I have seen ads for some optical tester, but I have never seen one in person. You fill test tubes and add reagent, then stick them inside and it reads and gives you a number. You might want to start googling for it.
    It would be nice if someone made a pH test as foolproof as the FAS-DPD chlorine test, wouldn't it?
    Guest
    Re: Testing kit
    I look for shades more than an exact match. I try to be as accurate as I possibly can, but I know it is not life or death, so shades are close enough for me
    Feb 2010
    Houston, TX
    271
    Re: Testing kit
    Quote Originally Posted by Richard320
    Sure would!
    All the pH kits should be pretty much the same (except the strips!), Richard and Bruce gave good advice.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Re: Testing kit
    Reading the colors on the PH test gets much easier with practice. It is best to hold the view tube up to a white surface that is lit by direct sunlight. Good lighting makes it simpler to distinguish the colors.
    If you really can't make the colors out, there are some alternative ways to measure PH that give direct digital readouts, but they cost around $100.
    Mar 2010
    Spring, TX
    1,082
    Re: Testing kit
    I am not able to find it and maybe someone can post it. There was a shade chart that someone has on here for pH levels.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
