Thread: Eyeball positioning
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Eyeball positioning
    So this is probably a no brainer but I need to ask any way. I have one return outlet in our 24" round pool. Is there a best way to have it positioned? I needed to move it and I'm not sure if I can get it back to exactly where it had been placed. Debris would round up in the middle making it easy to clean up but I don't know if that's best for water circulation.
    Thanks for any insight.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    Feb 2010
    Houston, TX
    271
    Re: Eyeball positioning
    Most on here recommend to have it pointed away from the skimmer and down at an angle. I put mine between horizontal and vertical, opposite the skimmer. Does that make sense? I can't think of a better way to explain right now, so I hope this helps!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Sounds good. I'm assuming you mean pointing down below the horizontal line?? I'm probably way over thinking this!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Feb 2010
    Houston, TX
    271
    Yep, down below. You're not the only one over thinking it! I'm racking my brain trying to find a better way to explain it!
    John
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    It's all good. I just wanted to make sure things are at their optimum. You can stop racking the brain. Sounds like that might hurt!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
