Help with Placido Polaris....
lynns
0
50
New Jersey
Yes, I named him Placido (any Phillies fan will know why). :wink:
A couple questions:
1: What does the tail really do? A friend says his swings back and forth pretty good. Mine just seems to drag behind.
2: The back wheel doesn't seem to touch the bottom sometimes. Almost like it's floating up. I know it cycles and floats sometimes but that's not when it's doing it.
3: Is he supposed to travel up the walls a little? He seems to be moving good and then get stuck in the corner.
I have the pump running at 1900. I tested the rpm on the wheels at this is more than enough power according to the manual.
BTW, it's a Polaris 360
I don't have a polaris and know little about them, but I do know the tail should whip around (my parents have one) and it should climb the walls. You've got a problem, and hopefully someone who can help will contribute!
