Results 1 to 10 of 10
Thread: Transitioning from Black Poly to PVC
    Pittsburgh, PA
    37
    What's the right way to transition from black poly pipe to PVC?
    If you want specifics on my situation my other thread about identifying black pipe provides pictures and a little background is-this-black-pipe-abs-t23809.html
    TFP Forum and the BBB Method Changed My Life!
    Dec 2009
    Central Massachusetts
    2,690
    Re: Transitioning from Black Poly to PVC
    You need to get a brass male adapter fitting that is barbed on one end. Nylon will work, but brass would be better. Might be hard to find 1 1/2 inch fitting thats not nylon poly looks 1 1/2 inch, is it?). If you cant find brass or stainless, nylon will do. Dope up the barbed end of the fitting with teflon pipe dope, put 2 CC clamps on the poly for later, heat the end of the poly with a torch for a second, then push the barbed fiting into the poly. Then, use both clamps around the fitting.
    Get a PVC fitting with a female threaded end and a slip coupling on the other. Use the teflon pipe dope and screw the PVC adaptor to the nylon/brass fitting. From there, it's PVC, primer and glue.
    A plumbing supply house is really where you need to go. Tell them what you want to do and they can fix you up with the right fittings.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I'd use one of these. It is almost as good and much less expensive.
    Dec 2009
    2,690
    That will work too, but the plumber in me, well...you know
    If you use what Jason suggested, you still need to use the teflon pipe dope, clamps, and heat the poly. This just eliminates the brass and the extra adaptor, and it is a touch cheaper.
    Pittsburgh, PA
    37
    Quote Originally Posted by bk406
    The outer diameter of the black poly pipe is 1.84 to 1.87 inches which I think makes it 1.5" poly. I'm assuming poly pipe is sized similarly to NPS/IPS.
    Are "CC clamps" just regular old plumbing grade hose clamps?
    Thanks guys. That procedure make sense. I was hoping for a solution involving glue or epoxy or something. Barb fittings with hose clamps make me nervous. I have a bunch of them underground anyway so I'll have to deal...
    To clarify I need:
    • one brass/stainless/nylon adapter that's 1.5" male NPT to 1.5" barbed[/*:m:3dw0sthe]
    • two stainless hose clamps[/*:m:3dw0sthe]
    • one pvc fitting that's 1.5" female NPT to 1.5" slip[/*:m:3dw0sthe]
    • teflon pipe dope (Oakley's Great White???)[/*:m:3dw0sthe]
    OR
    Is the white 1.5" barbed to 1.5" slip pvc fitting something a pool shop might have in stock?
    Dec 2009
    2,690
    Yea, you want the slip.
    Hose clamps yes. As long as you heat the poly for a second, and use the teflon pipe dope,your good to go.
    Dont worry about the mechanical fittings. You fix it like I told you, it will hold. See, all this glue and PVC are relatively new fangled stuff. It's good, dont get me wrong. I've used it and run a million miles of it. But, you have to realize that there are billions of miles (well, maybe not billions) of cast iron soil pipe thats been in the ground for decades that use nothing but mechanical fittings. When PVC and glue came out, you couldnt run it underground back then. It will leak, was the mantra. Now, you know what people who know only PVC say about mechanical fittings? "IT WILL LEAK" Also, PEX water pipe is almost industry standard now. Sweat and solder copper? Whats that?
    Pittsburgh, PA
    37
    Yea, I know.... What can I say? I like my welded connections.
    I'll see if I can source a stainless barb to mnpt locally. If not I may go with gray pvc. I found that mcmaster-carr has them. http://www.mcmaster.com/#48315k95/=7oghnz Of course they do. Mcmaster has everything!
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I really don't like to have brass or even stainless on chlorine piping. It's not usually a good long-term scenario. PVC is pretty impervious. Oh yeah, AFIK, PEX is not approved or recommended for pool use.
    Just my pair o' cents.
    Dec 2009
    2,690
    Quote Originally Posted by Ohm_Boy
    Yea, i know, just using it as an example of mechanical joints.
    Stainless, yea, probably wouldnt use it, good point. Not sure I agree on not using the brass, but nylon or PVC for this application would probably work just fine.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Kristof, sorry for coming late to this party
    In your linked post you said there were elbows below the ground - are they the same heavy gray elbows used above ground? If they are the cheap thin white elbows, remove them can run the PVC from there!
    If you need any help with either glued or mechanical connections - simply ask of us
    Luv& Luk
    -Ted
