Results 1 to 13 of 13
Thread: Need Help...Kids getting rashes...
    Hi, I have been using the BBB method on my pool for 3 years with great results. My father in law throws 1 cup of Leslies chlor brite sanitizer step 2 into his pool every day and now the kids are getting rashes where their bathing suits are. His water is crystal clear. So I brought mt TF100 test kit over to check out his numbers and I need advice on what to tell him. His pool is 22,000 gallon vinyl line inground pool in North Jersey.
    CL was off the chart for the basic tester. It was a bright deep yellow. I tested for FC and came up with 7 to 8 as his FC. His PH reading as well is way too LOW to even register in the test, it stays a light yellow color. His CYA has got to be some where up over 120 to 140. When I added the R0013 the water was ridiculously cloudy, after only a few ML i couldnt see the dot. When I tested for TA, after adding the r0008 after the r0007 the water turned very red and not green as it is supposed to. ***?
    So what do I tell him? Where do we begin? I am guessing draining and refilling with clean water would be a good start. Any help is greatly appreciated. Like I said, thanks to this site my pool is sparkling, and any little hiccups I can handle easily with all the great on this site. This just seems overwhelming to me.
    Thanks in advance............Brian
    Northern NJ, 14x32 inground fiberglass pool, 14,000 gallons, 1 1/2hp Hayward pump, Hayward c1200 cartridge filter, Pentair IC20 SWG , solar heat, mesh safety cover
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Need Help...Kids getting rashes...
    Brian, sounds like he uses trichlor and doesn't pay much attention to his pool! He has very low pH, TA = 0, and high CYA. I wouldn't want my kids swimming in it!! If he's willing, a drain and refill is indeed the best way to start.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    We had to drain our pool twice last week due to too much salt (10K ppm).... it's a pain but it's totally worth it!
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Did you measure the CC?
    If you know BBB, than you know that this is a classic case of too much CYA, not enough FC and not enough attention in general.
    The irritation could be cause by the low pH or by some biologicals that have take hold in the water.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    30,419
    Your very first hurdle will be convincing him that he needs to change what he's doing. If he does (and that's not a guarantee), then you will likely have to convince him of the need to test the water or do it for him.
    Those are not small tasks......if you can accomplish those, then you are ready to do some draining and help him get his pool in shape.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by yrreb13
    When the TA test immediately turns red, that not only means the TA is zero (or negative), but that the pH is <= 4.5 which is very low. No wonder it's irritating. The pH needs to be raised right away -- adding some sodium carbonate (Arm & Hammer Super Washing Soda or pH Up product) would be important to stop any metal corrosion that may already be occurring in his pool. Start with that and when the TA starts to register you can use 20 Mule Team Borax to raise the pH more if needed. I'd be careful about raising the pH too high, however, as he might have dissolved metals in his pool that could then stain.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I would do the drain/refill dance before bothering to adjust other chems - no one should swim in it right now anyway and you'd just be pouring chems down the drain.
    So get that CYA level down and then adjust the PH and TA, and begin to chlorinate properly.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by frustratedpoolmom
    Agree with FPM.
    I also have a feeling that it may be tough going to convince him that he needs to change his ways.
    We have started the drain/refill process and I will be testing the water again today. Thank you all for your replies and advice. I have already talked to him about switching over to the BBB method, and you are all right. The water is easy, the stubborn Irish father in-law is going to be tough to convince!!! Thanks again for all your help, I will post a follow-up with the end results when the happen. Wish me luck..........
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    hmmm....maybe some pints of guinness could smooth the road to agreement???
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Aug 2009
    North Central Texas
    1,358
    Maybe having one of the kiddos whisper in his ear thanking him for fixing the pool for them might work.
    Have kiddo do it like a secret whisper so he won't get embarrassed and/or rebel against your wishes/actions.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Guest
    We just converted a RV Park pool to the BBB method, after they got stuck in the dreaded "ChlorBrite" loop from Leslie's This was a pool that was so out of balance that there was no way that the guys onsite could maintain the water, even though they check the water twice every day! We put in a LQ, got them on bleach and MA, and got them a good test kit; you should have seen the look on their faces when they saw what the water could look like with BBB and how simple it really is!
    If you can get your F-I-L on board, he (and your kids!) will be much happier (not to mention all the money he'll save not buying ChlorBrite!). Good for you for showing him the way
    Jun 2010
    Long Island, New York, USA
    24
    Teach the kids the phrase, "Wow, grandpop - the pool is MUCH less acidic now! Thank you! We love you!"
    Good job dealing with the pool and the father-in-law. I can't imagine trying to convince mine of something that ran counter to his opinion.
    ~30K Gallon Vinyl IG, Triton II 24" 225# Sand Filter, Leslie HydraMax (Hayward Super II) pump
    Broken Hayward CL-200 Chlorohater, Dolphin Diagnostic cleaning robot
    TF-100 Test Kit
