Results 1 to 8 of 8
Thread: Help me understand vacuuming options
    Jun 2010
    Toronto, Canada
    34
    I'm about to vacuum my pool for the first time ever and wanted to make sure I understand the options I currently have available and the differences between them. Based on my reading and videos I've seen, it looks like I have the following options...
    1) Remove skimmer basket and connect vacuum hose directly to skimmer intake line
    2) Add skimmer vac plate on top of the skimmer basket and connect vacuum hose directly to the plate
    3) Connect vacuum hose directly to in-wall intake
    Can someone tell me what the difference is between each of these options and under what conditions I would use each option?
    Thank you
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help me understand vacuuming options
    Using the vacuum plate protects your plumbing from clogs if you vacuum up leaves or something large.
    Using the wall fitting allows your skimmer to keep working while you vacuum, but that's not really a big deal. Either way if you hook up without the skimer plate you should use a leaf trap.
    Jun 2010
    Toronto, Canada
    34
    Thanks, John. So it sounds like options 1 and 3 are the same except that the latter option allows me to also skim while vacuuming. Whereas, option 2 allows me to quickly capture leaves etc in the skimmer basket before they head into the plumping and the trap before my pump.
    Finally, when you say leaf trap do you mean the trap that's attached to my pump?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    A leaf trap attaches to your vacuum hose and catches leaves before they go to your pump. There's a picture of one here.
    Jun 2010
    Toronto, Canada
    34
    Quote Originally Posted by Melt In The Sun
    MITS, thanks for the info and the link to that great post!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP, eh!!
    A question you failed to ask, and was, thereby unanswered is - how to adjust the suction side valves to ensure proper vacuum suction.
    Fortunately I can answer the unasked
    Hook up your vacuum to whichever port or skimmer you want. Then go to the filter pad and close the valve to one (or more) of the other suction lines until you see a 1/2 - 1 psi drop on the pressure gauge - perfect suction without the vac head sticking to the floor!
    Also, if you didn't already know - fill the vac hose with water before attaching it
    Have some fun in the pool between vacuumings!
    Luv& Luk
    -Ted
    Jun 2010
    Toronto, Canada
    34
    Quote Originally Posted by waste
    Thanks, Waste! This forum is fantastic and is helping me get up to speed on the existing pool that came with our house.
    Just to be clear, when you say 'filter pad' do you mean the filter valves connected to my pump that are controlling the incoming water? I have 3 incoming lines (Skimmer, Floor Drain & In-wall Vacuum) with corresponding valves for each. Also, are you recommending to completely turn off one of the suction lines or just start turning it until the pressure drops 1/2-1 psi?
    These might seem silly, but since I have no previous exposure to these filter valves maybe someone can also answer these related questions:
    1) Can I turn the valves on/off while the pump is running? I know that the Multiport Main valve on my sand filter valve can only be switched when the pump is off so I'm wondering if the same rule applies to the valves controlling the incoming water?
    2) Does it matter which direction I turn the valves (ie left or right)?
    3) Do the valves only offer two states of water flow (ie on-off) or do they offer a variable range of water flow as I turn the valve futhur?
    Thanks again
    SW Indiana
    9,199
    Quote Originally Posted by cipher
    Yes, the control valves. Just adjust until you get the pressure drop you need.
    Yes. Adjust them as needed. The MP valve is much more complicated and actually opens all ports when it's being moved, plus the gasket is subject to dislocation by flowing water.
    2) Does it matter which direction I turn the valves (ie left or right)? 3) Do the valves only offer two states of water flow (ie on-off) or do they offer a variable range of water flow as I turn the valve futhur?
    Normally they'll go one way on, and the other way off, and they are variable.
