Results 1 to 14 of 14
Thread: Where did all my chemicals go?
    Jul 2009
    Northern California
    28
    End of last summer I had:
    TA 120
    CH 240
    CYA 70
    Borates 50
    This week I had:
    TA 80
    CH 70
    CYA 0 (less than 20 anyway)
    Borates 10
    The Pool Calculator tells me I would have had to drain 70-80% to drop the levels like that. Could I really have lost that much or do I probably have a leak? I use a autofill system.
    25,000 gal IG colored plaster pool, 6 years old w/ cartridge filter
    Mike
    • 20k gallon InGround pool, vinyl liner
      Hayward Perflex EC65 DE filter
      Sta-Rite pump
      Raypak Versa 155B heater (rebuilt 2011)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Where did all my chemicals go?
    If you're worried about a leak, shut off your autofiller and do a bucket test!
    Apr 2009
    Northeast Ohio
    221
    I'd suggest turning off the autofill and check for a leak. If it was only CYA, I'd say "That can happen, although it doesn't always", but since TA and CH dropped, I'd be searching for a leak.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    CYA can be converted to ammonia over the winter, and TA could drop on it's own, but CH wouldn't just disappear.
    It is probably worthwhile to check for a leak..
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jul 2009
    Northern California
    28
    Thanks everyone and svenpup thanks for the link.
    I checked for air in the pump basket - none and no bubbles in the pool. I checked around the equip pad for wet spots. Nothing.
    Next should I just shut off the autofill and wait? I won't worry about evaporation with the cover closed. Should I have the pump turned off for this test?
    Mike
      Sta-Rite pump
    Apr 2009
    Northeast Ohio
    221
    I'd turn off the autofill and leave everything else "as-is". If your level drops less than an inch, you may want to put a bucket next to it to check for evaporation all the same (don't know if your cover is mesh, or how that impacts evaporation.)
    Just getting the autofill turned off should let you see what's going on with the level. Just watch your water level so it doesn't get too low.
    Oct 2009
    3,899
    Since nobody asked, how are you testing? If those are pool store or strip tests, one or both could be bogus.
    Jul 2009
    Northern California
    28
    I use the TF100 kit.
    I'll mark my water level as soon as the kids are out of the pool, then see how much it drops in 24 hours. Will you guys be around tomorrow? LOL! Just kidding I know someone is always here when I need help! You guys are awesome!
    Jill
    Mike
      Sta-Rite pump
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    I agree. The people here at this forum totally ROCK!
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Water replacement seems like the leading theory, but there is another way this could have happened, though it seems much less likely. TA and CH both go down when there is calcium scaling. CYA can vanish over the winter. And the borate test is difficult to read with any precision, so the change in borates might not be real, or might be smaller than indicated. That requires three separate things to have happened, while water replacement only requires a leak and an autofill, but it isn't impossible.
    Jul 2009
    Northern California
    28
    So I thought my test was foiled by the unexpected rain we got today. But despite the rain I lost 3/8 inch in 24 hours.
    Now to find whether a leak is in the pool or the plumbing, what do you suggest I do? The instructions on leak detection say to plug the skimmers and drains but I can't think of any way to do that. Has anyone done this before?
    Jill
    Mike
      Sta-Rite pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The pool stores sell plugs, etc, for winterization. If your local dealer doesn't carry them, you could order from the internet.
    How many inches of rain do you get in the winter? does that get into the pool (cover solid or mesh?)
    Jul 2009
    Northern California
    28
    After doing a search I found a test I could perform:
    cya-dropped-from-50-to-20-t23869.html?hilit=pool leak
    My result was 1/2 inch loss with pump off vs. 3/4 inch loss with pump on. This would indicate a leak on the suction side of the plumbing. Of course I could have more than 1 leak.
    At this point is there a way to find the leak myself or is it time to call in the pool service? If I could find the leak I would probably have to have an expert fix it, but my local plumber would surely charge me less than the out-of-town pool service would. Any ideas?
    Mike
      Sta-Rite pump
