Thread: Do you recommend the foam cove?
    My installer says it is not necessary. Not surprisingly, the pool company says I should buy it! It does seem like the foam cove would be more stable, but it also seems like the installer would know what is best. What to do???
    WilBar Escalade 18x40 Oval AGP
    7' Hopper Style Deep End, 27K gallons
    Vinyl Unibead Liner
    Sand Filter
    Aug 2009
    Hattiesburg, MS
    84
    Re: Do you recommend the foam cove?
    I would go with the installer recommendations. The pool company is in the "sales" business. As long as your installer is one that can build you a good uniform cove out of sand, then you should be good. Does he guarantee his work? The sales pitch for a foam cove is that it will not wash away like sand when wet. I beg to differ. I had alot of trouble with my foam cove. We got a good afternoon thunderstorm mid build and the cove got wet after we had laid the liner, but before we hooked up our shop vac and started the water. Only thing that could have caused this was water getting under the wall track, or through the skimmer opening (at this point we did not have any dirt around the bottom of the pool. Once the sticky is wet, it's wasted. We pulled ours and built a cove out of sand because I didn't want the cove to shift under our liner. I know the weight of a lot of water would seem to hold the cove in place, but where there is an inch, and the way my luck went with the build, it would have shifted and ended up out of place. Foam coves haven't been around for forever and most pool company instructions recommend a sand cove. We have been fine with a sand cove and on our seconed season.
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    I used the foam cove, foam Happy Bottom, & foam wall liner when I installed my pool 14 years ago. When it comes time for a new liner or new pool, I'll do it all the same again. I like it & have had excellent results with it.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Another side of the foam cove coin is that we have one and it works very well. Uniform and stays in place. Our pool is about 3 years old and we haven't had one issue with it. In addition to the foam cove, we also had a foam bottom installed over the sand. I believe the pool store called it a "Happy Bottom". So far, we are happy with it. Nothing has worked it's way up through it and nothing has shifted.
    I suppose you could go and check out a few pools that have a foam cove and some that don't and then make that decision for yourself. Whatever you decide to do, you will have checked out all of your options and made a decision based on that.
    Good luck and happy swimming!
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I have had our old 18' pool with a sand cove and my current pool with a sand cove - we now have the foam cove, wall foam and Gorilla pad and this is most definitely the best setup - my vote is WITH foam cove
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Sep 2009
    Greentown, IN
    914
    We bought a used pool that had a foam cove and our installer actually encouraged us to reuse it. It was surprisingly still sticky and after cleaning the sand out of the grooves, snapped into the track beautifully. I'm glad we used it as it gives the edge a nice finish and hasn't shifted. If I had to do over again I would get the foam bottom as well.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
