Results 1 to 12 of 12
Thread: High Temperatures
    DeathB4Me's Avatar
    Jun 2010
    Las Vegas, Nevada
    23
    High Temperatures
    Hi, recently i noticed my pool water level goes down and i have been reading that is normal. Normally it losses about 1 or 2 inches in two and a half days, but sometimes it goes down about 3 to 3 1/2 in in three or four days. I live in Las Vegas, NV and the normal summer temp is about 102 F the highest is about 110 F.
    Is the water loss normal or at least in the normal range for the temp?
    21K gal, Pentair Cartridge filter, IG pool, Concrete, 2.5hp Pentair pump.
    Re: High Temperatures
    Quote Originally Posted by DeathB4Me
    Hi, recently i noticed my pool water level goes down and i have been reading that is normal but sometimes it goes down about 3 to 3 1/2 in in three or four days. I live in Las Vegas, NV and the normal summer temp is about 102 F the highest is about 110 F.
    I lose an inch or so every couple of days in the summer. I'm in South FL.
    TFP SUPPORTER through TFTestKits.com - My Pool: South Florida, 11K gallons, In ground, concrete / Diamond Brite, Free Form with attached spa (no heater- go figure) Built around 1998, original surface, Jacuzzi Magnum Force 1.5HP pump, Jacuzzi Cartridge Filter, Rainbow 320 Tablet Feeder, Hayward Navigator Pro, Taylor K-2006 w/ TFTestKits replacemeng Reagents.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    With temps above 100 F and very low humidity I would expect water loss in the range you're seeing.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You can do a bucket test to check. Fill a bucket partially with water, put it next to the pool, and see if the level goes down at the same rate as the pool. If the pool drops faster, you have a leak.
    DeathB4Me's Avatar
    Jun 2010
    Las Vegas, Nevada
    23
    I did that and left it for 3 days. on the second day i saw that the pool water was a little lower than the bucket but the next day i checked it was the same again. what was that about?
    Oct 2009
    3,899
    Ambiguity suggests that you don't have a leak, you just need to move somewhere with decent weather! Same as me...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Is the pool in full sun all day as well? That might do it!
    DeathB4Me's Avatar
    Jun 2010
    Las Vegas, Nevada
    23
    yes, i do not have a pool cover yet, should i get one?
    Oct 2009
    3,899
    That will make it even hotter! But will cut down on evaporation.
    DeathB4Me's Avatar
    Jun 2010
    Las Vegas, Nevada
    23
    Then i wont get one, the hootest it has gotten is like 84 F i dont want it to feel like a bath!
    Oct 2009
    3,899
    I hear ya, my wife likes it hot and keeps putting the cover on. It was 100 yesterday when I got home from work!
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by Melt In The Sun
    100-102 is our normal spa soaking temp, year round. In summer we like it a little less than 100 during day. So basically you have a big spool. :P
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
