Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: help needed re: muriatic acid
    Jun 2010
    Waco, Texas
    66
    I am trying to set up my pool. Bleach is in, I know I need to add muriatic acid....currently have a sock with stabilizer in front of the return. When/where do I add the MA and how? I need to add 2 qts for now. Can I do it with the sock thing in my way ...if I need to put it next to return? I am a tad nervous about handling the stuff.
    Kawfy
    AGP 16x32x52 Cornelius, guesstimate of 15400 gal. Dished out in center to 5 ft , Counter sunk 1ft 10"
    Jacuzzi 1.5 hp pump, 300 lb sand filter
    Full hot sun in Heart of Texas
    30,421
    Re: help needed re: muriatic acid
    I assume you have it in a one gallon plastic jug. I would remove the cap and carefully lower the jug partially (but not enough to submerse the mouth) down into the water to remove some weight and get the mouth closer to the water.
    Then, simply pour the acid gently into the water DIRECTLY in front of a return and it will disperse rapidly.
    When you feel like you have poured a little less than half, stop there and measure your pH in a couple of hours....adjust as necessary.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    How do you know you need MA? Post a full set of numbers so we can double check for you.
    A healthy fear of MA is a good thing. You should wear eye protection when handling the stuff. Pour it slowly in front of a return with the pump running. Try to keep the wind at your back so the fumes are blown away from you. Don't worry about the CYA sock.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2010
    Waco, Texas
    66
    Hi,
    Yes, sorry I was going to start my BBB yesterday but had an issue with the pump. My numbers were
    PH 8.2 according to the small blue test kit
    FC 3*.5 @ 1.5
    TA 35*10 @ 350
    CH 3*10 @30
    Bama responded with this
    1. If these numbers are the latest then here's what you should begin with.Add 1½ quarts of muratic acid to bring the pH down. (pool calc calls for 3½ but lets do it in a couple of steps.)
    2. Add 4lbs of stabilizer either in a sock in front of a return or slowly in the skimmer (don't backwash for a week).
    3. Add 2 quarts of bleach to bring the FC up.
    4. Wait and hour, test pH & FC and post results. When we know what the new pH number is we'll tell you how much more MA to add.
    I hope I didn't mess anything up by not doing another test this am in any case I guess what's done is done and I pray I don't have a big problem on my hands.
    The water looked the same. and it is still clear.
    I just added the MA will wait a couple of hours and then post new data here.
    Kawfy
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Sounds like you have it under control. You can go ahead and add the bleach now if you haven't already.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    I was wondering something similar this morning. Generally speaking, how long should I wait before adding MA after adding bleach?
    Thank you in advance.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I have seen 30 minutes here. I am sure it mixes to the point of being safe faster than 30 minutes, but better safe than sorry I guess. Sometimes I don't wait that long, but I will use my brush (with a whale tail) to give it a good mix.
    Jun 2010
    Waco, Texas
    66
    ok, wasn't sure what tests to do so I did them all and the results are as follows:
    PH 7.5
    FC .5ppm
    CC .5ppm
    TC 1
    TA 310 (surprisingly did not change even after MA)
    CH 30
    CYA 50
    What should I do next?
    Kawfy
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Did you add the bleach? You minimum FC for CYA = 50 is 4, so you should be targeting 7 or so. Have you familiarized yourself with the Pool Calculator (link in my signature)?
    30,421
    Next, put enough bleach in to reach 5ppm.
    Understand that bleach is consumable and you will need to add it daily to keep your pool crystal clear.
    Then read Pool School.......especially the first few articles. That'll help you get a good understanding of what your testing and why your testing it. It should also prompt you to ask more questions.
    How does your water look?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by kawfytawk
    PH 7.5
    FC .5ppm
    CC .5ppm
    TC 1
    CH 30
    CYA 50
    Looks like your TA dropped from 350 to 310; is that right? That sounds about right for the amount of acid you added. If you didn't already know, when you're testing TA it helps to wipe the dropper tip with a damp cloth after every couple drops. Sometimes static electricity builds up and makes the drops much smaller than normal, giving the impression that the TA is a lot higher than it actually is.
    You need to get some chlorine in there! The pool calculator can help you figure out how much.
    Jun 2010
    Waco, Texas
    66
    Yes I added the bleach ....according to the calculator plugging in my new readings I should add another 3 qts. which I will do in just a sec.
    yes, I am trying to use the calc. I am new to it and really trying to guess at my water volume. I could be off on my CYA test
    Kawfy
    Jun 2010
    Waco, Texas
    66
    ok, yep the TA did go down. I did wipe after every drop because the very first time I did it I got a reading of 510
    This is my very first time adding anything to this pool or any pool for that matter. I will add the bleach and retest. Do you think I need to add more MA? The calq did not say so. But I know I must aerate as well.
    I really appreciate all the help
    Kawfy
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    If you are following the Lower Total Alkalinity instructions you can go lower with your pH (7.0 to 7.2) which will allow you to take a bigger chunk out of the TA with each cycle.
    Jun 2010
    Waco, Texas
    66
    sven...ok so according to pool calq I add 1 gallon plus 2 cups of MA.....this means in 32 oz increments slowly in front of return?...and when folks say slowly are we talking trickle?
    Kawfy
    Jun 2010
    Waco, Texas
    66
    can anyone swim in the pool now to create the aeration?
    Kawfy
    Oct 2009
    3,899
    I'd give the acid some time to mix in, but otherwise as long as you put in the bleach and nothing's visibly wrong with the water, I would probably swim.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    A stream like the diameter of a pencil would be good. It should take two minutes to add a whole gallon.
    Alternatively you could add the acid to a 5 gallon bucket of pool water to dillute it and then broadcast that in the pool.
    Always add Acid to Water. Never add Water to Acid!!!
    Playing in the pool is an excepted method of aeration!
    30,421
    OOps! Let's hold on that addition for a minute Why are you lowering pH?
  20. Back To Top    #20
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Duraleigh, Kawfy is trying to lower TA, but I see what you are getting at...
    I get 2 quarts of 31.45% MA to drop pH from 7.5 to 7.2 in 15,400 gallons
