Thread: Rainforest Blue - Same as Baquacil?
    Jun 2010
    Dallas, TX
    11
    I am converting over to the BBB method, but going through chlorine like nobody's business (4 gallons a day... after getting started on the program with 24 gallons in my 11K gallon pool).
    After reading a posting on Baquacil, it got me to wondering. Earlier this summer, I tried a product called Rainforest Blue to be more "green" in the pool and minimize the chlorine usage. I'm now wondering if this Rainforest Blue is pretty much the same stuff at Baquacil.
    Do any of you have any experience with Rainforest Blue?
    http://www.pacificsandsinc.com/html/pool_closing.html
    11K Gallon IG Diamond Brite Pool with a Cartridge Filter - 1.65HP Pump
    Re: Rainforest Blue - Same as Baquacil?
    Rainforst Blue is copper sulfate based, not the same as Baquacil at all. We strongly recommend against using copper based products. Depending on how much you used, it would be a good idea to get your copper level tested. Copper can cause unsightly stains that are extremely difficult to remove.
    Jun 2010
    Dallas, TX
    11
    Is the copper sulfate causing more bleach/chlorine requirements?
    I'm just surprised at the amount of bleach required so far.
    No, copper sulfate won't have any effect on the conversion. The only possible issue with copper in the water is staining. Other than that it will just sit there and "not get involved".
    Baquacil conversions do require dramatic amounts of chlorine. I've conversions that took anywhere from 20 to over 100 gallons of 6% bleach.
