Thread: T/A Levels
    NE Ohio
    63
    T/A Levels
    My TA has been hovering between 130 and 140 and my PH around 7.5.
    Do I need to reduce my TA levels? According to the pool calculator, is shows
    it should be between 70 and 90+, but to lower my TA I need to lower my PH, but that is right on track.
    Any thoughts?
    Thanks!
    24" Round Above Ground 52" high
    Jacuzzi CFR 100 Platinum Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: T/A Levels
    If your PH is stable and you have no SWG or water features, then your TA is fine.
    NE Ohio
    63
    Re: T/A Levels
    Thanks!
