Results 1 to 14 of 14
Thread: Need Help!
    Apr 2009
    Louisiana
    64
    Need Help!
    I hope this is the right place to post. I first posted in BBB but moved it here. Our pool was finished last summer & really had no problems. This year we have a few "slick spots" but no visible green. I have been studying the pool school & put our numbers in this morning.
    These are our readings:
    CL less than 5
    PH 7.2
    FC 4
    CC 0
    TC 4
    TA 90
    CH
    370
    CYA 55
    It looks like I need 63 oz stabilizer, 45 oz baking soda, & 62 oz borax? I don't understand why it doesn't tell me that I need bleach because my CC is 0. My water is not sparkling clear like last year. Hopefully someone can start me down the happy BBB path!
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Need Help!
    Your TA is fine, no baking soda needed, the ph should rise on it's own from the use of the SWG so leave that alone too. Don't adjust CYA yet, lets figure out what's happening with the clarity/quality first.
    What are you testing with?
    You should do an overnight FC loss test with the SWG off to determine if organics are the problem.
    Overnight FC Loss Test
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    Thanks for the quick reply! We have the TF-100 kit. As for the overnight CL test, does that mean test at night & again in the morning?
    11,969
    Re: Need Help!
    Good! then you can do the overnight test properly. In the post is a link to the instructions for doing the overnight loss test, the instructions are step by step
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Need Help!
    Yes, test at night when the sun is off the pool and make sure the SWG is off as well. Test again at dawn before the sun is fully up. This will show how much FC is lost to organics in the water. Sunlight causes FC to burn off, if you wait until the sun is up you may show more FC loss than you really have overnight.
    Love TFP? Become a
    TFP Supporter!
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    Will do! Thanks so much for the help. I'm ready for our pool to be sparkling clear again. I'll post results again in the morning. Another question - should I post on this thread or start a new one?
    11,969
    Re: Need Help!
    Post on this thread
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    Good Morning! Just did my overnight FC test. Last night was 5 1/2 & this morning was 6 1/2. My husband insists that the slick spots just need a good brushing. What do you think? Like I said, it is just in a few spots. Thanks so much for all your help!!
    22,544
    Re: Need Help!
    Did you have the SWCG off before testing last night?
    If so how long before testing did you turn it off?
    Did you test for CC's also?
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    CC was 0 and we did turn the SWG off 3 hours befor testing.
    11,969
    Re: Need Help!
    The SWG was off and your FC went UP?
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    I asked my husband & he did say that the SWG was off. We checked it about 10 last night and again this morning about 6. Am I nuts? We haven't added any chemicals at all in 4 days.
    11,969
    Re: Need Help!
    That's a bit unusual... I suggest repeating the test tonight. Let the SWG run today, turn it off about 7pm. Test the FC at about 10pm, then again in the morning. It prob means you passed the test but lets verify that tonight just to be sure
    As far as the slick spots, have you tried brushing them? How often do you brush the pool?
    Apr 2009
    Louisiana
    64
    Re: Need Help!
    We did brush this morning and normally brush about once a week. I do notice the slick spots are not where we mostly hang out in the pool. I have 3 grandsons - 2,1, 9 months, so we stay in the shallow end quite a bit! I am going to go out shortly & work on it some more. Will repeat test tonight & again in the am. Thank you so much for the help!!
