Thread: PH rising using alot of acid and not sure why
    Topic Split off by Moderator
    I'm putting about a Gallon of acid(31.45%) every two weeks in 13,000 gl pool - old plaster, SWG, Borates (50) - not getting used a lot yet this summer. Why is Ph climbing so fast?
    Irvine, CA
    IG Plaster 12,600 gallons, saltwater.
    SWG
    D.E. Filter - 48 sq. ft. 96GPM
    1 1/2 H.P. pump.
    Kreepy Krawly
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: PH rising using alot of acid and not sure why
    Can you post a full set of results so we can advise you better... any water features besides the SWG?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    That actually sounds about right to me. Maybe a little high, but not much more than I use. First, I have hard water. If add 2" of fill water I have to add 2 cups of acid just to stay even on pH. Second, I have some real light calcium scaling that is slowly dissolving (we're talking months and months) by keeping pH down below 7.5 all the time. (and brushing with a steel brush) Third, I have to keep water flowing through the spa portion so it gets filtered, and there's no way to stop the bubbles. I have it down low, but it still gets a lot of aeration. Which isn't necessarily bad, as it gets rid of the TA. But it uses a bunch of acid.
    Once the TA gets down to about 80, things stabilize quite a bit. But then it gets hot, water evaporates, I add more, and it all starts over again.
