Thread: operate and program jva's via jandy one touch control panel?
    How do I change and program the jandy valve JVA's via the jandy aqualink one touch? I'd like to have the 'spa fill' on for an hour or two to circulate the spa water then have it change to 'filter mode' for the remainder of the filtering duration. Can this be programmed, I can't figure it out and have to do it manually every day. The spa bypass doesnt move much spa water while in the low speed mode.
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
    Re: operate and program jva's via jandy one touch control panel?
    bump!
    Cleva-Chlor RP40HD
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Great question! I would also like to do this.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Since there are no replies and nothing in the manual, and I can't find anything on the one touch, I'm starting to think it's not possible. This is amazing to me. Seems like it would have been so simple. How does everyone control there valves? Do I really have to go to the equipment everytime I wanna change these?
    Cleva-Chlor RP40HD
    Okay. I talked to a Jandy tech support guy. He said you have to make sure that nothing is using aux 3. Then change dip #3 to the on position. That will automatically add the label, "spillway" to your equipment list on the one touch and allow you to set a program for it. I had my lights on aux 3 so I switched them to aux 4, flipped the dip switch and it worked. The only problem was that it still will not allow you to activate the spillway when low speed is enabled. On my system the SWG was connected to the low speed circuit of the pump so I had to remove it and place it on aux 5. So now I programmed the spillway to be on for 30 minutes while generating chlorine.
    Cleva-Chlor RP40HD
    This was a really helpful post. I have a similar issue in that when my filter pump is on a low speed it doesn't push any water to the spa. I was able to turn on the spillway feature via DIP 3 and configure its associated "speed #4" for 1000 RPMs. At 1000 RPMs the onetouch panel states I'm using around 58 watts.
    I'm still toying with how to keep my pool clean and electrical bills low.
    I'm thinking I'll try keeping the filter pump on for maybe 3 hours a day at around 2500 RPMs to push water around and keep the vacuum moving. And then run it for most of the time (maybe always) at 1000 RPMs on Spillway. At 58 watts I suppose I'll never need to turn it off. It's a little hard to believe this giant pump can use less electricity than a light bulb. I haven't toyed with my aquapure yet so I'm not exactly sure what I'll need to do when I turn that on. Pool is still too new to add salt.
    Shelley
    Denver, CO
