Thread: Spot acid treatment for pebble bottom pool
    I posted earlier that our neighbor had some issues with what looks to be small rust marks on their stonescapes pebble pool bottom. The plaster guy came out and used a small circular tool that had a small chemical hose that attached to the pool pole. He placed it over the rust mark and hit it with acid. It cleaned it right up.
    What is it and where can someone get there hands on one?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Re: Spot acid treatment for pebble bottom pool
    Hi there~~
    It's called a Jandy Stain Master. Google it, and good luck!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Thanks- Ill let em know
