Thread: Borates question
    Jun 2010
    Rural Southern Illinois
    49
    Borates question
    Probably a little silly, but does adding Borax alone, no acid, add borates to your pool? I have put some Borax in my pool, but no acid. Well I've put in stabilizer which I guess is an acid. But I think someone probably understands what I'm getting at. lol, hopefully!!!
    Thanks, David
    17100 gallon 27' Round 4' Deep Above Ground Pool
    Hayward Cartridge Filter 1 HP pump 50 GPM flow rate
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Borates question
    Yes, but to add a meaningful amount (50ppm) without acid your pH would go through the roof
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    FYI, CYA is a weak acid so it really doesn't have much effect on pH.
    Mar 2007
    San Rafael, CA USA
    12,082
    You can use the "Effects of adding chemicals" section at the bottom of The Pool Calculator to estimate how much you are increasing your borates by using Borax to raise the pH. As noted, it isn't very much but if you are using Borax a lot over time it can build up. However, if your pH tends to fall (which is unusual if using chlorinating liquid or bleach or Cal-Hypo) then you could raise your Total Alkalinity (TA) level which should help balance the pH and keep it more stable since a higher TA causes the pH to rise thus balancing out the fall in pH you are seeing.
    Jun 2010
    49
    Thank you guys for all that info!!!
