Results 1 to 10 of 10
Thread: Need to Shock
    Need to Shock
    FC 6
    CC .5
    PH 7.5
    TA 110
    CH 250
    CYA 70-80
    Pool is in full sun 9-8. I add bleach every night usually FC is between 5.5- 7 so i use calculator to figure up to around 9. It takes any where from gallon up. My cc is always .5 I have some gray stuff in the skimmer don't know if it's from bathers, lotion etc. or algae. Wondering if I need to shock is that a lot of bleach to add every night or is it because of sun and high CYA? Thanks for any help.. Maybe I should do a overnight FC lost test. What do you all think?
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Apr 2009
    Northeast Ohio
    221
    Re: Need to Shock
    The overnight FC loss test will let you know if there is organics in your water. I agree that's what I would do first.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    22,542
    Re: Need to Shock
    I'd recommend doing the overnight test then shock if you need to.
    Get a couple of scum balls too. They'll catch most of the stuff you're talking about. It's probably from the swimmers.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Need to Shock
    The question of what is "normal" FC loss has come up a lot lately. 3ppm per day is not excessive. You could do an overnight FC loss test to get a better idea of where the FC demand is coming from and whether you need to shock.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Need to Shock
    If the CYA were truly 70-80 ppm, then the typical chlorine loss starting from 9 ppm FC would be roughly 2 ppm FC while you are seeing a drop of 2 to 3.5 ppm. Though this is still plausible, it does seem a little on the high side (unless you have very high bather load, especially if people are peeing in the pool). The gray stuff in your skimmer may be a sign of excessive organic load in your pool. I presume you have backwashed your sand filter recently and seen dirty outflows turn to clear. You might want to inspect the filter just in case there is clumping with channeling -- that can happen from biofilms though they normally don't form unless the chlorine was too low at some point in time.
    As others have noted, a test of the overnight drop in FC would help you determine whether you should shock and/or look for organic contaminants in your pool (i.e. checking the filter, skimmer, pump basket, etc.).
    Re: Need to Shock
    Thanks for the input i've been running my robot and not backwashing since the pressure never changes. I guess I need to backwash and do an overnight loss thanks. Oh what is a scum ball?
    Central, VA
    Re: Need to Shock
    A scum ball is a ball made out of a special foam material. You put it in your skimmer and it soaks up any oils, suntan lotion, tanning oil, etc that get into the skimmer. They can be handy if you have oil accumulating inside the skimmer.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Need to Shock
    Can these be cut in half and still be effective?
    I just got some (oooohhh 33% bigger now!) and it is a bit too big for the skimmer...the lid keeps it in one place.
    Plus I'm cheap, err, thrifty, and I like to get the most for my money...Seems like there's a lot of space that doesn't get used.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Re: Need to Shock
    Sure you can cut them up.
    Re: Need to Shock
    FC 8 after adding bleach and checking 45 min. later. But this morning checked it was FC 9. Guess I need to check again tonight and wait longer after adding the bleach. I also need to back wash at least once a week even know I'm using the robot? I guess just the amount of sun my pool receives and the high CYA is the reason I need to add so much Bleach every night. Next year there will be no pucks or sticks used in the pool and hopefully I can keep the CYA down some. But with high sun exposure do you need to keep CYA at the higher end? thanks again for the input. This site is great!!!!!
    Central, VA
