Thread: Bleach adding procedure
    Jun 2010
    Round Rock, TX
    20
    I'm about to take my inline chlorinator offline and switch to bleach, but there is one piece of info I can't seem to find. I'm sure it's here, but I'm having no luck. Anyway, I want to try to add around the same time each day and with my schedule, that'll end up being late evenings, probably after the pump has turned off for the night. I know I should have the pump running when I add and pour in front of a return, but do I need to leave the pump running for any length of time after adding?
    Thanks!
    15K gallon IG gunite with waterfall; 1.5 HP Pentair WhisperFlo pump; Pentair CC200 (200 sf. cartridge filter); 3/4 HP booster pump; Polaris 280; Levolor Electronic Water Leveler
    Apr 2009
    Northeast Ohio
    221
    Re: Bleach adding procedure
    You need to run the pump at least an hour after adding chemicals including bleach.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    22,553
    You should leave the pump running enough to mix the water. An hour should be good enough. Sounds like you might be a candidate for a liquidator or SWCG. That way you don't have to worry about adding it when the pumps running. It's added automatically while the pump is running.
    Jun 2010
    Round Rock, TX
    20
    I thought that might be the case, just couldn't find it anywhere. Thanks!
    I've been doing a little reading up on the liquidator and it is something I want to do. I want to wait until I get the hang of this first.
    Can someone expand on what you mean by "liquidator"?
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    The Liquidator is a device that adds bleach/liquid chlorine to the pool slowly any time the pump is running.
