Results 1 to 16 of 16
Thread: FC Loss
    FC Loss
    Readings As of Yesterday:
    FC 5
    TA 100
    CH 260
    CYA 46
    pH 7.7
    I live in South Arkansas and we've been averaging 95-100 temp. over the last couple of weeks. I'll have anywhere from 2-6 people swimming in my pool daily. Most of the time just 2 adults and 2-3 very small children. I have very little shade. What should be my daily max FC loss assuming no other bacteria or contaminants?
    Alan
    Fiberglass
    17,500 gallons
    Sand Filter
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    This has come up here recently. The consensus is that it is hard to define since every pool is different but 2-3ppm per day seems to be acceptable.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Re: FC Loss
    Even with a fairly heavy swimmer load? I think I'm losing quite a bit more. Hmmmmm. And I'm not losing any overnight.
    Alan
    Apr 2009
    Northeast Ohio
    221
    Re: FC Loss
    Where are you getting your test results? Your CYA reading of 46 is too precise for either the Taylor K-2006 or TF-100 test kits and makes me think your numbers might be from the pool store. If so, they could be inaccurate and you might have something else going on with your water. Otherwise, you might just want to say CYA = 40 or 50, since it can't get closer than 10 ppm.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    What is your CC? Have you done an overnight FC loss test?
    Re: FC Loss
    I'm getting my results from the TF-100...it just looks like it's around 46 on the cylinder. I haven't done an overnight FC test in about a month. Maybe I should do that again. However, the water looks great! I'm just spending a lot of money on bleach.
    Alan
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    CC?
    Even if CC < 0.5 you may still need to shock if overnight loss > 1.0
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FC Loss
    Each person-hour of people (with some swimming) in your 17,500 gallon pool would have a chlorine demand of around 0.06 ppm, though that assumes no peeing in the pool. If the children (or adults) pee, then that can shoot your chlorine demand way up. One cup of urine in your pool would create a chlorine demand of around 0.4 ppm FC.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    Quote Originally Posted by chem geek
    ...One cup of urine in your pool would create a chlorine demand of around 0.4 ppm FC.
    Richard, there is no limit to your knowledge.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: FC Loss
    Quote Originally Posted by svenpup
    No kidding! Richard tracked an FC loss from his own pool a couple years ago...........
    and it was/is one of the most entertaining threads on TFP
    Richard may decide to link us up
    You're done SLAMing when:
    ssa's Avatar
    San Jose,CA
    26
    Re: FC Loss
    Quote Originally Posted by Butterfly
    I want to see that.
    15x32 vinyl, IG,17K gal, DE filter, Hayward 3/4 HP pump, Hayward Ultra Vac, Solar cover with reel
    SportCount LapCounter, FINIS SwiMP3.1G
    Enjoying my pool thanks to TFP.com
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    Based on this data I could come up with an equation:
    • You enter baseline daily FC demand, FC demand for a pool party day, number of swimmer hours, and solve for cups of pee.
    Maybe we could get Jason to add it to the Pool Calculator.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FC Loss
    The thread you are looking for is Unusual Chlorine Demand -- Peeing in the Pool. Yes, with your trusty FAS-DPD chlorine test kit and knowing the "normal" chlorine demand in your pool without the "extra" bather load, you can indeed detect when someone has been peeing in the pool. Whether you want to actually disclose/question a certain person about your suspicions is another matter.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: FC Loss
    When I checked my pools pH it was all pee, no H.
    Re: FC Loss
    My CC is .5 or less and I performed an overnight FC loss test last night. I had a reading of 8 at 9:30pm and a reading of 6.5 at 6:30 this morning. It was daylight at around 6:00, but the sun didn't rise near the pool area until around 7:00ish. Should I have tested before daylight to get the most accurate reading, or should I be convinced that something else is in the pool if I lost 1.5 ppm between 9:30 and 6:30?
    Alan
    Apr 2009
    Northeast Ohio
    221
    Re: FC Loss
    You need to get the morning test before the sun is on the pool, with 1.5 ppm seems like a lot to lose with that little bit of sun. I'd shock it again tonight and get an overnight FC loss test without any sun on the pool (evening or morning) and see what it looks like. You've probably got a few more days of shocking to do.
