Results 1 to 7 of 7
Thread: adding salt to a plaster pool
    I am going to be adding salt to a newly plastered pool. (It has been 30 days.) Do I add the salt to a bucket of water,let it dissolve,then dump it into the pool or do I just add the salt directly into the pool?
    24,500 gallon plaster i/g
    sand filter (Hayward S-200)
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: adding salt to a plaster pool
    You can just dump it in and brush it until it dissolves.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Does the salt go into the deep end or all over the pool? Also I know to run the pump for 24 hours but do I turn on the SWG immediately?
    Turn the SWG off for 24 hours after adding salt.
    You can add the salt by dumping it in almost anywhere. Brush it around so there aren't any large piles, give it 15 minutes, and brush whatever remains to help it dissolve.
    Thank You to all
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    ditto to Jason
    Make sure your read though water balance saltwater generator and get all other your levels right (CYA, TA, etc).
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    I would like to make a suggestion based on my personal experience with our SWG. If you haven't already, do yourself a favor and purchase this salt test kit. No matter what the installer says, don't rely 100% on the panel reading of the SWG. The danger is that if it is a low reading, you think "oh, I better add salt." Then if the reading is incorrect & your salt level is actually fine, and you add salt, you have to drain the pool to fix that issue (excess salt). If you independently test the salt with a salt test kit, you avoid that drama, which is, believe me, drama.
    Interesting to note that when our Pulliam pool guy comes out to test our water he does not go by the AquaRite display - he uses an independent salt test kit.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
