Thread: 3-Way Valve Description Question
    I'm looking for a valve that will have one inlet and two outlet ports. Preferably all 3 ports will be 2" or 1.5" Glue. Critical to me is that the inlet will never be shut off from the outlets. The input will either be full to output port 1 or 2 or any mix in between, just never closed to both. A partial turn valve with a big handle would be helpful to understand how the outputs are balanced / set.
    Can anyone enlighten me as to what this type of valve is called and where to find them? The 3-ways I've seen so far have the possibility of becoming completely closed if mis-adjusted.
    Thanks......Dave
    23,000 In-Ground, Hayward Sand, Hayward 400 BTU Heater, Pool is 30 years old.
    Vero Beach, FL
    462
    Re: 3-Way Valve Description Question
    The Jandy's have stops to keep this from happening and the Pentair ones have adjustable pegs that act as stops. https://shop.solardirect.com/images/p_p ... alve_d.gif
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Sweet........Thanks..............Dave
