Thread: Another dumb Pool Calculator question
    How does water temperature factor in to water testing? It isnt mentioned in my DPD test instructions, didnt catch the guy at Leslies checking the temp when they did a test for me.
    Feb 2010
    Houston, TX
    271
    Re: Another dumb Pool Calculator question
    The water temp changes the CSI (calcite saturation index), which shows the likelihood for corrosion or scaling of the pool surfaces and equipment. Others here could explain the CSI better than me, but that's it in a nutshell.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Plausible temperatures don't have very much effect. If the water is below 70 degrees, you should allow it to warm to room temperature before testing the CYA level. You should always test the FC, CC and PH shortly after getting the water sample while it is still at whatever temperature it started at. With very cold water you will need to mix the TA and CH tests more between drops, or risk missing a slightly delayed color change.
    Feb 2010
    Houston, TX
    271
    Whoops, must have misunderstood.. I thought the OP was referring to why the Pool Calculator has a place for temp, hence the title of the thread.
    John
    I definitely got the answer, and a bit more valuable info as well!
