Thread: Polaris 380 and regular Vacuum
    We have a Polaris 380 in our pool. We have it programmed to run a few hours each day before we get home from work. It does a good job of keeping the pool clean. Is there a need to use the regular vacuum or is the Polaris sufficient? After I treat for iron staining the product (StainFree) states that you should thoroughly vacuum the pool. Is the Polaris good for that or should I pull out the hose with the vacuum?
    Thanks for your help!!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Polaris 380 and regular Vacuum
    Creechy, if the Polaris gets the pool clean enough to satisfy you, I wouldn't bother with the regular vacuum.
