Thread: pump confused
    Apr 2010
    Central NJ
    227
    pump confused
    My pump is leaking from the motor side and I thought I knew what I was going to buy....http://www.poolcenter.com/gokit3.jpg since I have a superpump 2610X15, at least that's what one of the stickers says, but then I noticed that the motor doesn't say hayward, it's a AO Smith UST1152. Is it the same pump just rebranded by hayward? Can I use the kit I was going to buy? If not, where can I get a kit for it?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: pump confused
    Hayward uses AO Smith motors, I had to replace the motor on my single speed 1.5HP Hayward Super Pump a couple of months ago, the replacement was an AO Smith UST1152
    22,537
    Re: pump confused
    The kit you quoted will work. Regardless of who made the motor, they have to conform to the frame standard, so parts that fit one mfg's motor will fit anothers.
