duraleigh said:I certainly think so. Typically, I only run mine during the day.Wondering if there would be enough cooling to make the extra cost to run it worthwhile....
The evaporative process requires the temp/dewpoint spread to be reasonably wide to be effective. In other words, there's no evaporation if the humidity is 100%.
At night, the humidity approaches that 100% level and very little evaporation occurs. In the day, especially in the Southwest where there is no humidity, the water evaporates quite readily and that's where you transfer the heat out of the water.
Droplets of water from a fountain landing on you in the daytime heat will feel COLD. Evaporation makes the fountain/sprayer/cooler work....not temperature differential.
True, but at night you're not fighting the solar heating of the water. Hmmmm...I forsee a test in my future..temp loss during the day vs temp loss at night w/ the fountain running.
