Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Hot water...
    Jan 2010
    Southeast Missouri
    33
    Hot water...
    Hi All,
    Having one of the hottest Junes on record here, our pool water temp is now 90 degrees. The only way I know to lower the temp is to drain and refill which would mean starting over with balancing, adding more CYA, etc. Thought of trying to put in some block ice but don't know how well that might work. What does everyone else do to keep your pool water from feeling like a bath?
    Dave in Sikeston, Mo.
    27' AG, 16K, vinyl, 1.5 HP pump, Pentair Meteor sand filter, Hayward Aqua Rite 25K SWG, Pentair E-Z Vac cleaner, TF100 test kit
    30,421
    Re: Hot water...
    Hi, Dave,
    This works and it's cheap!!
    a-cheap-pool-cooler-for-the-end-of-summer-t2501.html?hilit=cheap pool
    Dec 2009
    Central Massachusetts
    2,690
    Re: Hot water...
    You "my pool is too hot" people are a little sickening. In New England, my heat pump still kicks on in the morning most days for at least a couple of hours
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Western Pennsylvania
    151
    Re: Hot water...
    My heat pump also runs for about 2 hours when I turn it on, mostly as my pool only gets 3 hours of sunlight a day!
    I have 47 trees around our back yard!
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Re: Hot water...
    Huh, I am definitely noticing temps in the low 90s here too... not exactly refreshing.
    Do you think aerating with a pair of deck jets will help cool the pool as described in that other thread with aerators? Best to do day or at night? Does it increase the pH significantly?
    Thanks!!
    -Andrew
    12,800 gal. fiberglass freeform pool, appx 30x14x3-6, Pentair pump & cart filter, Autopilot Cubby SWG, Polaris 280, auto lever
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Hot water...
    Dave and Andrew,
    Either build your own fountain like Duraleigh did, or you can buy one either online or from a pool store. They usually connect to your return via a plastic hose, or attach directly to your return. Run it at night, and you should see your water temps drop. I've been running mine at night, and I'm getting about a 6 degree temp drop overnight. You can run it during the daytime too if you'd like, although the temp drop won't be as much as overnight. Kind of refreshing to let the water rain down on you though during the day - you'll be surprised how much cooler the drops of water feel compared to the pool.
    Or, if you have a solar heater connected to the pool, I've heard you can run that at night and cool the water as well.
    edit: Yes, it will cause your pH to rise, but you can keep it in check with muriatic acid. This may lower your TA too (basically the same method to lower TA), so keep an eye on that too.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Hot water...
    I'm going to be using my deckjets to shoot my water up in the air. Water is 90 degrees. With my pump on high I can get quite a bit of elevation. Probably not as high as Dave's but high enough to get some cooling affect.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    30,421
    Re: Hot water...
    Lynn,
    It's certainly worth a try but you may not be able to get the deck jets to produce drops of water rather than a steam. The smaller drops you can get, the more significant the cooling.
    Is there any way you can attach a "nozzle" of some sort to produce a spray rather than a stream?
    Re: Hot water...
    Thanks guys. I will experiment with deck jets and see how that goes before trying the fountain or to modify the jet spray. Running the pump overnight shouldn't be an issue either.
    That, or just wait for the summer temps to really kick in here. I'm sure 91 degree pool water feels good when it's over 100 outside (until the water gets hotter)
    -Andrew
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Hot water...
    Quote Originally Posted by bk406
    Why do you think I moved from RI to CA?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Re: Hot water...
    I was excited yeterday when the temp finally hit 80
    Intex 16x48 Ultra Frame
    5100 gallons
    Intex Sand Filter and Pump
    BBB Bliss Baby!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hot water...
    Quote Originally Posted by Britmandogs
    I'd be glad to ship you 6 degrees if you can figure out how to ship it.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Hot water...
    Quote Originally Posted by JohnT
    And 6 more from me....this is crazy for JUNE!!!
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Re: Hot water...
    We're finally suppose to hit mid 80's for the next week or so, the kids thought the pool felt like a bath tub last night at 80, hopefully 85 is on its way...then I can finally get in.
    5100 gallons
    BBB Bliss Baby!
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Hot water...
    Lynn,
    Hey Dave. I think if I aim them up in the air more I'll get drops. I was going to ask you though, I have 4 different patterns I can use, one being a mist. Could I use that and get more cooling, or would I get too much evaporation I normally just use the 3 stream pattern with my pump on low and have the valves wide open. With pump on high I have to adjust them or else they shoot out into the yard
    Lynn
    30,421
    Re: Hot water...
    I considered making mine "mist", too. It would take a lot more holes to produce the kind of volume you need.
    Eventually, I decided against it as I felt the water would blow out of the pool. (I still get some that doesn't make it back in if it's at all windy)
    Anyway, the more water surface you can expose to the air, the more cooling you will experience. Misting would be great if you can move enough water volume and keep it in the pool. Both of those things might be hard to do, though.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Hot water...
    I've never tried the mist pattern with my deck jets, but I think I'm going to with all this heat we're having. I'll just swap out one of my jets and give it a try. Might be just the ticket If I like it maybe I'll keep 2 misting and the other 2 with the 3 streams. I'll let you know how it goes
    Lynn
    Jan 2010
    Southeast Missouri
    33
    Re: Hot water...
    Thanks for the ideas. I was beginning to wonder if I was the only one that didn't like bath water to swim in! I was going to build a fountain like Dave's in the picture out of PVC, but the threads on my return are in between 1-1/2" and 2" pipe threads. Any idea what that could be? Are all eyeball return collars a standard thread size?
    I went ahead and ordered a fountain online and should get it next week. It said it would cool water temp by as much as 15 degrees which would be great. Will just have to keep an eye on pH and TA and adjust as needed.
    Another person I talked to here said they froze one gallon water jugs and put several in their pool to drop the temp. That would work too and would not affect the chemical balance but maybe more hassle to carry them back and forth from the freezer to the pool, if you have a freezer big enough to hold that many. I think the fountain idea will be the simplest.
    Thanks again for your help!
    Jun 2010
    Sachse, TX (near Dallas)
    8
    Re: Hot water...
    I just posted in another thread but we hit 97 degrees in the pool today I had already ordered two misters and received and installed them today. The fountain we tried last year did absolutely zip. If I can get 6 degrees overnight at least I'll start at 91, but I suspect I'll be right back up to 97 tomorrow afternoon.
    Has anyone tried running the pump 24x7? Wondering if there would be enough cooling to make the extra cost to run it worthwhile....
  20. Back To Top    #20
    30,421
    Re: Hot water...
    I certainly think so. Typically, I only run mine during the day.
    The evaporative process requires the temp/dewpoint spread to be reasonably wide to be effective. In other words, there's no evaporation if the humidity is 100%.
    At night, the humidity approaches that 100% level and very little evaporation occurs. In the day, especially in the Southwest where there is no humidity, the water evaporates quite readily and that's where you transfer the heat out of the water.
    Droplets of water from a fountain landing on you in the daytime heat will feel COLD. Evaporation makes the fountain/sprayer/cooler work....not temperature differential.
