Results 1 to 7 of 7
Thread: normal filter pressure
    My question is what is normal pressure for my filter? I just had a new pool put in and my filter stays between 5-10 psi. My builder says its low but didnt say anymore. I dont know if this is good or bad. My pool is 18000 gallons, with 2 skimmers and 2 floor drains, my pump is the vs-3050 with the large pentair filter.
    33x24 gunite pool, hayward4.0 LED light, vs-3050 pentair pump, clean and clear plus 520, rainbow 320 chlorinator
    Re: normal filter pressure
    There is no "normal" pressure, every pool is different. Remember that with a variable speed pump the filter pressure will vary with the pump speed. Lower pump speeds mean lower filter pressure.
    South Central NJ
    3,192
    What speed is the pump running at? Where the preset speeds changed? Sounds like you are running on a relatively low speed, say about 1700 rpm. At 2300, I would expect about 16 PSI.
    Scott
    Owner of - PoolGuyNJ LLC
    I think the highest is 1900 or something like that. I know I will have different pressures for each setting. I was just worried since he said it was low and I have noticed a lot of dirt and rock build up in the skimmer (but its a brand new pool...3 weeks old). Not much has been in the pump filter though
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Quote Originally Posted by tkutch
    You may as well ask, "What is the normal weight for a woman?"
    Answer: every one is uniquely different. If its flowing good and filtering effectively, it's working, and that's just your normal pressure.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Low Pressure -> Low Flow Rates -> Low Energy Costs
    Don't worry be happy!
    Mark
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by Richard320
    Are you sure you want to go there?
    Luv& Luk
    -Ted
