Thread: New to Pool School...working well...but
    Hi! This is our first post here. We had a horribly green pool this year and stumbled upon the website and have switched to using bleach and such after pouring, literally, $215 for chemicals to open the pool...yet it stayed pretty and green.
    Right now, we have very pretty blue water...but cloudy. We have a cartridge filter, which we have been spraying clean every other day. We shocked the bejebers out of the pool with bleach for the past week and a half and it has improved to where it is...it just doesn't apprear to be changing from cloudy.
    We would like it to be clear by the 4th of July for our family and friends, so any advice on getting it to clear would be appreciated.
    Thank you soooo much!!
    We had the water tested at the pool store today because our test strips only read for 4 things (FC, Bromine, Ph and TA)
    The readings were:
    FC: 1.6
    CC: 1.6
    pH: 7.8
    TA:110
    CH:67
    CYA: 0 (though this shouldn't be right. We put 4 lbs in initially. Drained the pool halfway then put another lb in (got frustrated and figured we'd start over). The pool guy said that the test might have been bad...so no help there).
    Borates:n/a?
    Thank you again for any feedback! It will be greatly appreciated!
    (don't know where the signature is...maybe it will ask me later, but here is the information, just in case!)
    We are in Springfield, MO and have a 13,600 gallon above ground pool. We have a cartridge filter, though I am not sure of the size, though, in my opinion it is HUGE (probably 18 in tall). I know the pump is a 1.5HP pump, if that helps. The liner is vinyl, I believe. Otherwise, I am not sure on other pool information. We bought the house and pool from the previous owners with no previous information.
    30,000 gallons / sand / IG / Vinyl
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: New to Pool School...working well...but
    If your CC reading is correct than you are not done shocking. Even when you are done shocking it can take a while for all the dead algae to get filtered out, so be patient.
    You really need an accurate CYA reading. This is the key to keeping your pool clear. Without a CYA reading how do you know what your shock level is? Unfortunately your are using inaccurate strips followed by inaccurate pool store measurements. I recommend that you get a good test kit (TF-100) and take control of your pool. If you are concerned about the price, just think about how much you spent at the pool store and still couldn't get your water clear.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
