Thread: Jack's Magic The Purple Stuff questions
    Aug 2008
    Honolulu
    429
    The first question is does Jack's Magic "The Purple Stuff" create any chlorine demand, if so how much per oz delivered in a 10,000 gallon SWG pool?
    The second question is when they state maintenance are the referring to weekly or monthly?
    Any help would be welcome.
    Thank you.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Re: Jack's Magic The Purple Stuff questions
    The maintenance dose is weekly, and only approximate. Some pools require more, some less.
    There is some minimal chlorine usage, but it is small enough that you can usually ignore it.
    Aug 2008
    Honolulu
    429
    Jason Lion,
    Thank you, this stuff just became available locally in Honolulu for the first time that I know of in the last 15 years. Other Jack's stuff has been available but not "The Purple Stuff".
