Thread: Help with Above ground pool!
    Need help! Got an above ground pool. 5600 gal FC Chlorine is 12.5 and PH is 7.2. Can someone tell me what I need to do now? Using shock and 6% bleach.
    Thanks!
    Tesa
    22,544
    Re: Help with Above ground pool!
    Welcome to TFP.
    What exactly is your problem?
    How are you testing?
    What does the water look like?
    You need to read pool school on the basics. That'll tell you what info wwe need to help you with your issues. We are happy to help you and once we understand the problem you're having you'll get plenty of good advice about how to solve it.
    Welcome to TFP.
    What exactly is your problem? PH low?
    How are you testing? With your pool test kit. FC is 12.5 and ph is 7.2
    What does the water look like? Cloudy
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Welcome to TFP!
    What are the other tests showing?
    FC 12.5 still?
    CC ?
    pH 7.2 still?
    TA ?
    CH ?
    CYA ?
    And water is still cloudy, right? Post all test results, including re-doing FC and pH. Then we'll take it from there.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
