Thread: Old waterfall/pond
    Old waterfall/pond
    I have an old waterfall/pond that is fed directly by the filter return. I believe it was original to the pool in 1978. It is two levels (top level overfills into lower level, which overfills back into pool). It is constructed of stone w/ concrete and rebar supporting the top level. I have noted that the rebar on the bottom of the top level appears to be rusted and detaching from the concrete. I have also noted that the concrete is really chewed up and shows the aggregate from years of chlorine and wear.
    1. Should I be concerned about the rebar on the bottom? There doesn't appear to be any structural issues.
    2. If I drained the pond and shut off the return. Is there something that I could coat the concrete with that would either seal it or ensure that I'm not having any leaks through or losing water?
    3. What's the best way to make sure that this rock pond/waterfall lasts?
    I haven't found any posts addressing these specific concerns. Thanks - Newbie.
    1978, 30K, IG, White Plaster 1999, free form elongated with spa and waterfall overflowing into pool, 1 separate main drain, 1 skimmer, 1 spa main + skimmer, 3 returns + waterfall, 10 ft deep end with very fast decline from shallow, Raypak Gas heater w/ electronic controls, 1.5 HP filter pump, 1.5 HP Silencer spa blower, 3/4 HP Booster Pump with Polaris 280 cleaner.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Old waterfall/pond
    Some pictures would help immensely. It sounds pretty neat!
    Here's a far away pic...I'll post a really old one that you can see better next.
    Here's one I got from the original owner...probably taken in the 80's.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    There's all kinda concrete sealants avaialble. That's a big sucker!
