Thread: Floating Chlorinators
    New pool owner here. The guy from the startup pool service told me to dissolve the chlorine tablets by placing 3-4 per week in my skimmer basket, but I've seen the floating chlorinator devices for sale at the pool store and was wondering if they really provide any additional benefit. I understand that as the device floats around the pool, the slowly dissolving chlorine is getting deposited throughout the pool. But don't I really get just about as much distribution by just dissolving them in the skimmers and letting the chlorine get deposited throughout the pool via the returns?
    Any advice on whether I should bother using the floating chlorinator?
    Tim
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Floating Chlorinators
    You are not going to find many proponents of using tablets at all here.
    First I'll answer your question. Tablets in the skimmer basket are only OK if you run the pump 24/7. Trichlor (pucks/tablets) are acidic so if they are sitting in your skimmer with the pump off the water in becomes very acidic. When you turn the pump on all that acidic water goes undiluted into the pump and filter.
    Now for the real issue. I recommend that you read through Pool School and gain an understanding of the CYA/Chlorine relationship. The tablets you are using are adding stabilizer every time you use them. The chlorine is consumed, so you have to keep adding pucks, but the CYA just keeps building up.
    The best thing you can do for yourself is become educated about pool chemistry and get a good test kit.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by tim_pool_newbie
    Tim
    Save it for vacation. You'll end up with too much stabilizer if you rely on pucks alone. It's a headache. I suggest you spend a couple hours reading Pool School. 4 hours reading there could save you 4 weeks trouble at the pool. And get your own, proper, test kit ASAP. It will probably have to be ordered online. There's an article in Pool School that explains the differences.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    If you absolutely positively have to use one, then absolutely positively make sure the top is locked closed on it. You don't want one sitting on the bottom of the pool. Kids are also notorious on "tampering' with them.
