Thread: Should I add 11 gallons of bleach
    So I have sparkling clear water but can see a little green on parts of the walls and floor. I brushed it two days ago and filter it, but it's back. Here are my numbers with my new t100 testing kit.
    FC: 5, CC: 0, TA: 5, PH: 7.2 - 7.5, TA: 110, CH 300, CYA: 60, Plaster 35K Pool
    The pool calculator says I should add just over 11 gallons of bleach. Should I do this? When should I let swimming begin again?
    I'm new to the BBB method but love everything about it. Please help me learn more. Thanks... Dan
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Should I add 11 gallons of bleach
    Welcome to TFP
    Although your #'s and lack of CCs would not indicate a need to shock, you may want to bump up the FC a few (2-3) ppm first and perform an overnight FC loss test. This will help you confirm whether you need to shock or if it may be a circulation issue.
    30,431
    Like dman, I suggest you elevate the FC up to around 8 maybe even 10ppm and then hold it up there until all traces of algae are gone. I would also suggest someone get in the pool with a deck brush and brush the green areas.....that'll expose them to the chlorine and kill them.
    If there are too many to brush, you need to begin the shock process and still brush as much as you can.
    I took the FC up to 10 and did the brushing. Pool looked very good this morning with no FC loss. I'll check it again at the end of the day. Thanks for all the help.
