Thread: timer box wiring for pentair ch 250 milivolt
    I am attempting to switch an old heater with a pentair ch250 natural gas milivolt. The qustion I have I followed the wire from my old heater to my automatic timer box. The gas valve and temperature setting knob are tied split together leading to the timer box. I do not know where to attach the wire from the timer to the pentair heater . I am thinking it would tie into the orange wire going to the gas valve Any help would be appeciated
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: timer box wiring for pentair ch 250 milivolt
    Davemonk, welcome to TFP!
    I have no idea how to help you, so...
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    The wire from the timer is probably a fireman's switch. there should be a labeled wire on the heater where to splice into. You'll have to look around . Check the manual for possible splice location.
    Factory Warranty Station for:
    The manual is here, look for the remote switch connection indicated on the wiring diagrams for the various models.
