Thread: Colorlogic self install
    Jun 2010
    Southington, CT
    17
    Hi, I am an extreme newbie here and have a few questions about the colored lights.
    We are installing a 18 x 36 grecian pool in our backyard. I like the idea of the colorlogic lights. I think that they would look great in our pool, however we will have a somewhat dark liner and a friend suggested that we install 2 lights. My PB quoted me a price of $900 per light which to me seems outrageous. I have found these lights on line for less than half that. A standard white incandescent light is included in the cost of the pool installation. My question is, how hard is it to change out the incandescent for a colorlogic system? What about the switching and the changing light shows? Will I have to install any additional electrical or do I just basically plug in the new light and put a new controller box where the switch is?
    I imagine that if I want to install two colorlogic lights I will have to have my PB install ad wire two niches. Is there anything I am missing?
    18 x 36 IG Grecian
    21,000 gallon, vinyl liner
    DE filter with 2 speed Hayward pump
    Re: Colorlogic self install
    very easy to install just make sure the light will fit the niche. Not sure if there is a standard size or not
    18' x 36' saltwater inground vinyl pool
    Aug 2009
    North Central Texas
    1,358
    Welcome to TFP.
    If you get standard Edison fixtures, using incandescent bulbs, you can just simply replace the incandescent bulbs with the LED bulbs. Make sure the lights are on the same circuit so they will synchronize. You won't need to add a transformer if you go with 120 volt. Not sure about how 12 volt initial install goes but the replacement bulbs do come in 12 volt. That is the least hassle and least expense. And yes, with a dark liner you will really appreciate, and probably need, the two lights. Even my medium blue plaster absorbs some of the light. When I replaced my incandescent bulb with an LED I had a lot more white calcium scaling on my plaster. Now that there is not as much white scale, and more blue plaster showing, I can see a reduction in the "brightness" of the light from one end, where light is located, to the shallow end and side steps.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
