Results 1 to 18 of 18
Thread: Should I Drain Swamp Pool? A journey with pictures.
    We're buying our first home and it has a pool. The pool hasn't been used in at least 6 months and the pool cover is floating in the water. The water is black and all you can see is the occasional toad on the surface. It's bound to have leaves and sticks and dead bodies at the bottom. My family says to drain the whole thing and start over, but others tell me this is dangerous. The pool is in ground with a vinyl liner. Any advice or alternatives is appreciated.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,100
    Re: Should I Drain Swamp Pool?
    Welcome to TFP.
    You don't want to drain it. It would be very difficult to get the liner smooth again.
    Read
    Defeating Algae
    and
    Turning Your Green Swamp Back into a Sparkling Oasis
    for information on clearing the water.
    Your first step should be to get your hands on a good quality test kit. The Taylor K-2006 or the TF-100 at TFTestkits.net will do what you need. It will be the the best investment you can make to save you time and money clearing the pool.
    Thanks JohnT!
    I'm obviously new to this pool-ownership thing. What's the best way to go about getting solids out of the pool?
    Should I get the water clear(ish) and then fish out what I can see? Or should I try and scoop out the best I can, add chemicals based on test, and then scoop out the rest?
    Jan 2008
    Northeast Florida
    161
    If there are solids there, I would start by pulling out what you can see with a leaf net, then consider starting the filter (if it is functional) and get what you can out through filtration before dumping in chemicals. If you have a floor drain, I would shut that off for now, at least until you can see what is down there. Just use the skimmer to turn over the water and check the skimmer basket, pump basket and filter pressure very frequently. What kind of filter?
    Question for the experts....I understand draining the pool is a problem with a vinyl liner, but if it is really bad, would a partial drain and refill be a good idea?
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Thanks Miranda!
    We haven't moved in yet, so all of this is planning. I'm not sure what kind of filter it has. How would I check that?
    Also, how do I know if it has a floor drain and how would I shut this off?
    SW Indiana
    9,100
    Quote Originally Posted by louisianapool
    Thanks Miranda!
    The easiest way to figure out what you have is to post a picture of the equipment area. Better yet, a few pictures with different angles so we can get a view of where all the pipes go.
    Will do. I have a couple of pictures of the pool. No close-ups of the pump. I'll post what I have and I'll make sure to take more as soon as we can get back to the house.
    Mine becomes a swamp every year and we recover every year. My hope for you is that you don't discover a bunch of hidden problems as you move ahead to enjoying your pool.
    23,000 In-Ground, Hayward Sand, Hayward 400 BTU Heater, Pool is 30 years old.
    Re: Should I Drain Swamp Pool? A journey with pictures.
    Here are a few pictures to start with. I'll post more detailed pictures of the pool and pump and continue as we progress. Thanks to all for the help so far!
    ssa's Avatar
    San Jose,CA
    26
    Nice pool.
    Please don't drain the pool. It is definitely no no for vinyl pool.
    Do you know how old is the vinyl? If you drain the pool, the vinyl
    will shrink because there is no water pushing it against the wall any more.
    The vinyl can be misaligned after the refill. In the worse case the liner might
    crack. Then you are looking for a new liner, which is very expensive.
    Go ahead and post some picture of your pump and filters.
    You should order a TF100 test kit. While waiting for the test kit,
    try to get the solid stuff out from the pool as much as you can.
    Hopefully nothing wrong with the pump and filter. When the test
    kit arrived. You can start the shock process to clear the pool.
    Look forward to your pump and filter picture.
    15x32 vinyl, IG,17K gal, DE filter, Hayward 3/4 HP pump, Hayward Ultra Vac, Solar cover with reel
    SportCount LapCounter, FINIS SwiMP3.1G
    Enjoying my pool thanks to TFP.com
    ssa's Avatar
    San Jose,CA
    26
    Quote Originally Posted by Miranda
    Partial drain and refill does not help much on defeat the algae. They grow
    very fast.
    You might need to partial drain and refill to get the CYA level down, if CYA
    is too high.
    The picture shows some stairs at the end of the pool. The linear on the
    step of the stair might pop up even for partial drain. So unless I know there
    is a good reason to partial drain it, I would avoid it.
    Aug 2009
    North Central Texas
    1,358
    Welcome to TFP.
    Beautiful yard and soon to be beauiful pool.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Thanks for the info on partial draining SSA. My wife and I were actually just discussing whether or not this was a good idea.
    Do any of the Taylor pool tests have the same contents as the TF-100? The Taylor brand seems to run cheaper. Plus it's sold on Amazon where I have a "prime" account and get cheaper shipping. Just curious.
    Thanks Geek Granny! We look forward to getting in the yard and getting some work done.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    ...Do any of the Taylor pool tests have the same contents as the TF-100? The Taylor brand seems to run cheaper. Plus it's sold on Amazon where I have a "prime" account and get cheaper shipping. Just curious.
    The Taylor K-2006 is also recommended, but it is more expensive in sense that is comes with a much smaller amount of reagents. I bought the K-2006 at the beginning of this season, and have already had to get replacement chemicals (from TFTestkits I might add).
    DO NOT GET THE K-2005. It is not the same. You want an FAS-DPD kit.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    ssa's Avatar
    San Jose,CA
    26
    Not exactly the same. See this link for more detail compare of the test kit.
    pool-school/pool_test_kit_comparison
    One big different is the CYA test, which use a lot of reagent. You need to
    put the a lot reagent in a tube to see how clear it is. TF100 has a lot more
    8 oz vs 1.5 oz.
    I think considering the free shipping on amazon, TF100 is still a better deal.
    If I were you, I might even get a TF100 XL because you have a green pool right
    now. You are going to do a lot of FAS-DPD test during the shocking process.
    TF100 XL has double the reagent for that (and CYA).
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Gorgeous place!
    Looking to build a new POOL
    Thanks MyBad!
    Like I said, we still haven't moved in and the previous owners are still in the process of moving out. I plan on changing a lot of the landscaping including adding a safety fence for the pool.
