Thread: Did you get your Phosphate level tested?
    Split off of this topic. This was getting off topic for that thread. JasonLion
    Did you get your Phosphate level tested at the pool store? Before draining your pool to get the cya down to 40 ppm, you might want to check your Phosphate level. I have found the following links helpful.
    Phosphate
    http://ezinearticles.com/?Phosphate-in- ... id=2137181
    http://www.allchlor.com.au/newsview/phosphate-13
    http://www.askalanaquestion.com/phospha ... oblems.htm
    Liquid or Bleach Chlorine
    http://www.poolspaforum.com/forum/index ... opic=18434
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: very frustrated. water is now green?
    Phosphates... that looks an awful lot like forum spam.
    The basic tenet is that if you get and keep your pool properly chlorinated, you won't have algae. If you don't have algae, you needn't worry about or spend money on algae food (phosphate) control.
    neophyte, welcome to TFP!
    While removing phosphates can help slow, or even prevent, algae growth, chlorine alone does a perfectly fine job for less money and with far less trouble.
    Feb 2008
    Denton, TX
    5,061
    There is no reason or need to address phosphates, present or absent, in a properly sanitized swimming pool. If you have the correct amount of chlorine, phosphates are nary an issue.
    I see. After using up the 9 liter of Phosphate free chemical, I will discontinue its use. Thanks!
