Thread: Screw broken in automatic pool cover...
    I have a PoolSaver automatic pool cover. Unfortunately the screw inside the motor has broken. So, while the motor is rotating fine, it is not turning the wheel which holds the rope.
    I belive I can open the assembly and put in a new screw. But - what kind of screw do i need?
    Any help will be really appreciated.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Screw broken in automatic pool cover...
    Alpana, welcome to TFP!
    Can you get the old screw out and match it at a hardware store? Sorry I can't be more help.
