Thread: Bleach or Shock Powder- Which is the Better Deal?
    Comparing the two...
    Walmart Bleach - 182oz @ 6% = $2.67
    1lb Kem-Tek "Shock Quick" - 40% "Trichloro-s-triazinetrione" = $2
    Not sure how to do the math to compare liquid chlorine to powder chlorine. But the Shock Quick seems to raise my chlorine levels more than the bleach. Is that the better deal?
    Plus, it's stabilized, right?
    • 10k Gallon Pool[/*:m:26tadf53]
    • Cartridge Filter (Hayward)[/*:m:26tadf53]
    • In-ground, Plaster[/*:m:26tadf53]
    • 2.4hp pump/ 150gpm filter[/*:m:26tadf53]
    • Los Angeles, CA[/*:m:26tadf53]
    Feb 2008
    Denton, TX
    5,061
    Re: Bleach or Shock Powder- Which is the Better Deal?
    It's really kind of apple to oranges as a comparison. You use one when you want CYA and the other when you don't.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The problem with the tri-chlor is potentially raising your CYA/stabilizer levels too high where the only practical solution to lowering them is a partial drain and refill (unless you are lucky enough to live in an area with a reverse osmosis pool service). If you need to raise the CYA and need to shock the tri-chlor may be the right option, otherwise it is best to get your CYA levels to the correct point and keep them there through very occasional use of tri-chlor or dry or liquid stabilizer.
    Ike
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    http://www.troublefreepool.com/cost-...ces-t1859.html
    This article is an in depth look at how bleach comes out being the cheapest method for chlorinating the pool.
    Ahhh..good to know. I won't make it my regular source of chlorination then.
