Thread: Installing Swimpure 40k- easy?
    is it easy to install the swimpure 40k system? is it hard to work with PVC piping? I heard you shouldn't have too many elbow connections? if so, why? thanks.
    Re: Installing Swimpure 40k- easy?
    Welcome to TFP!
    Installing a SWG is fairly easy if you have any DIY experience. PVC is fairly easy to work with. As with most things, plan and measure carefully and things will go well.
    Elbows introduce flow resistance, which lowers the efficiency of the system. Adding one or two is not a big deal, but adding quite a few elbows starts to have a significant effect.
    22,553
    It depends on your definition of easy. Working with PVC pipe is easy if you're handy. The reference to too many elbows has to do with flow restrictions. If you have an excessive amount of elows it restricts the flow through the cell.
    Thanks very much for the info. This will help me a lot.
    Yep installing my CPSC took just a few mins. Took longer to dig the hole that the control unit was mounted to then it did to plumb in the actual cell.
    But as mentioned - please, please measure it twice before cutting. Once cut DRY FIT EVERYTHING first before gluing!! Also don't forget to turn off the pump and close your valves so water does leak out of your lines before you cut.
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
