Results 1 to 18 of 18
Thread: Before and After
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Before and After
    The week we were moving in....
    Looking to build a new POOL
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Re: Before and After
    ...and now ...with lots of help from the site!
    Casey's Avatar
    SW PA
    10,424
    Now that's just total awesomeness! Show off!
    Looks great!
    Feb 2008
    Denton, TX
    5,061
    Very nice!
    Guest
    What a beautiful transformation! You should be very proud
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Aug 2009
    North Central Texas
    1,358
    The blue tile is very pretty.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Butterfly's Avatar
    South Carolina
    10,045
    Having the before and after pics really tells a story! Looks fabulous
    You're done SLAMing when:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Great Job...time for a party
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Quote Originally Posted by geekgranny
    gg=alice
    Thx everyone...wish I could find the last couple of pieces of missing tile on the spa dam though. I re-attached what I could find from the bottom of the pool, but a few were missing. Can't seem to find a match anywhere.
    May 2008
    florida
    112
    Nice transformation! I bet it was a lot of work.
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    Let the Good Times Roll!!!
    32.6K Gallon 16x41x24 L-Shape Vinyl Inground by Fort Wayne Pools
    DE Filter, 1HP Pump, Sta-Rite 400,000 Btu Propane Heater, Pentair IC40 SWG
    One Wife - Three Kids - Two Dogs
    Guest
    Quote Originally Posted by MyBad
    gg=alice
    Did you check National Pool Tile (www.nptgonline.com)? They might have it, or something real close.
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Yah I did find something kinda close there...I even thought of putting in like a depth marker sorta thing...just to fill it in. Thx for the link.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The after is just a wee bit more inviting looking!
    great transformation!
    14'x28' vinyl liner inground 3.5-6' deep wedge hopper 15000 gal (used to say 13000- I calculated wrong), 1 hp pump with sand filter, 2 returns, 1 fountain, traditional chlorinated, pool house.
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Beautiful!!!
    5,000 Gallon 16'x 48" Intex Ultra Frame, Waterway 1hp sand filter, Intex SWG, AquaCritter, TF100
    Climate/Location: SW Iowa
    Just starting BBB . This is SOOOO inspiring!! Awsome you.
    23k gal IG Vinyl Liner
    Sand Filter Pentair Pump VS
    Electric Heat Ft Wayne Indiana
    Built 2012
