Thread: SWG and copper pool lines
    I was talking to a pool plaster guy yesterday and he mentioned there were salt water generators that worked with copper lines. Anyone here of such a unit? I was wondering if he was confused with one of those mineral and chloine tab dispenser units.
    I am planning on replastering my pool and thinking about changing out the copper pipes with PVC so I can eventually add a SWG unit.
    18 ft round (Intex style) Summer Escape pool
    1hp Hayward pump and sand filter (size escapes me)
    Intex SWG
    Planning an upgrade to a 24ft as soon as we wear this one out!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: SWG and copper pool lines
    I could (very easily) be wrong, but I thought the main issue with copper lines was pH (i.e. never below 7.0), not salt.
    Replacing copper pipe with PVC is always a good idea, SWG or not. Copper is very sensitive to low PH.
    There is no problem using copper pipes with a SWG. Most people don't have copper pipes, but many many people have copper heat exchangers in their pool heaters that are used with SWG pools.
