Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: want to drive a wrecking ball through my pool!
    Jun 2010
    Dayton, Ohio
    241
    A little background first....
    my pool sat unused for two years with no cover.....so you can imagine how attractive it was when I started working on it. I didn't know if I should go fishing or put in chemicals. I was going to drain my pool but after extensive research realized that would do nothing more than ruin my liner. So began my descent into a mental breakdown......I got a leave rake and spent six hours dredging out leaves and muck...smelled like a sewer. I took sample of water to pool store and did whatever they told me. it went from black to cloudy blue/green pretty quickly. I have probably used 26 gallons of liquid shock...bought whatever I needed to buy to get all withing correct levels. Here are my current numbers
    TC 15.......was told to keep it between 15 and 30
    FC 15
    pH 7.5
    TA 120
    CH 275
    Stabilizer 40
    Langelier index value 0.13
    Pool store said my chemicals are balanced. And now I have a "**** floating in pool" problem. So, I used clarifier and when that failed I used floc....I know that is a bit controversial but used it none the less...I have what looks like snow floating in my pool. Dead algae? thats what I am told. I clean my filter around 6 times a day and clean the muck off of it. Never does my pool clear...I can see about 18 inches into my pool. Driving me nuts...I truly feel like I have done everyting I can.
    Any help would be appreciated.
    Thanks.
    Lori
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Re: want to drive a wrecking ball through my pool!
    Ok cancel the wrecking ball. Your pool is reacting much like it should. Its going to take some time to clear a pool thats been ignored for that long. Filter cleaning , brushing and maintain your shock untill it clears. It may take a week or longer but it will clear.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Jun 2010
    Dayton, Ohio
    241
    Well at least I am working in the right direction.....feels like a neverending battle.
    Whiskey normally helps.
    coloeb,
    Jul 2007
    Northern NJ
    299
    You are definitely going in the right direction. You just have to keep in mind that it took 2 years for the pool to get in that condition. It isn't going to clear up right away. It's going to take a little bit of time.
    What are you using to test the water? Are you doing it yourself or are you taking a sample to the pool store to be tested?
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Apr 2009
    Northeast Ohio
    221
    What are you using to get your test numbers? If you don't have a good test kit already (with a FAS-DPD drop chlorine test), I'd recommend getting one of those (Taylor K-2006 or TFTestKits.net TF-100).
    How long have your been keeping your pool at shock level? I'd recommend performing an overnight FC loss test to see if this is a filter issue, or an organics issue (or both.) Bring your pool to shock level in the evening after the sun is off your pool. One hour after adding the chlorine, test you chlorine level and record it. The next morning, before the sun is on your pool, test the chlorine level again. You need to continue shocking until:
    1) the overnight FC loss is 1ppm or less.
    2) the CC level is .5 ppm or less.
    3) or if you don't have a FAS-DPD test kit, your pool is sparkly clear.
    If you don't have an overnight FC loss, you're done shocking and any issues you have clearing your pool are filtration related. How old are your cartridges? Have you carefully inspected for tears? How often are you cleaning them?
    If you do have an overnight FC loss, keep you pool at shock level bringing it up as often as you can (even hourly if you have the time.) Brush every surface you can reach and pay attention to ladders (even the underside), step and and recesses like lights that might be in the pool. Keep shocking until you meet the above criteria.
    With a pool that's been neglected for so long, it may take several weeks to get everything clear and under control, but you can do it and once it's done, with proper maintenance, it will stay that way.
    Good luck and make sure to post if you have any questions or want to update with your progress.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Jun 2010
    Dayton, Ohio
    241
    I will do the FC overnight test and see what happens. I am beginning to think I need to replace the filter cartridge. It has never been replaced and it is four years old.
    It would not hurt to have a new cartridge on hand.
    coloeb,
    Jun 2010
    Dayton, Ohio
    241
    considering how much I am having to clean the filter will a new one be ruined within a week?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Unless your old one has holes in it, it is fine. Can you tell if it is allowing debris to go back to the pool? Those cartridges are pretty tough. You have a lot of stuff in your pool that needs to be filtered out, and getting a new cartridge won't speed that up (unless your old one does have holes in it). Time for some POP = pool owner patience. You will get that pool clear!
    Jun 2010
    Dayton, Ohio
    241
    There are no holes in the cartridge. It appears to be in okay condition. Just cant believe that pool is so cloudy. If I turn off the filter it gathers on the stairs and when I aggitate it, it stirs around like a snow globe.
    Oct 2009
    3,899
    Is it clogging up quickly? If so, it's doing its job and you just gotta wait...
    Jun 2010
    Dayton, Ohio
    241
    yeah very quickly..I should be cleaning it every hour or so.
    Jun 2010
    Dayton, Ohio
    241
    I seem to be holding chlorine overnight, I will run a sample to the pool store this morning. Initially I would put in a ton of chlorine and in the morning have none. That is not the case anymore. I also have noticed that in the morning I can actually see the bottom step on the stairs. When I turn on the pump its back to snow globe, less snow globe but.......yeah you get the point.....Anything I should be doing besides cleaning cartridge all the time, and making sure all levels are good?? bty I run the pump 8 to 12 hours a day. If there is something else I need to do please share! Thanks,
    Lori
    Apr 2009
    Northeast Ohio
    221
    While you're shocking and trying to clear the pool, you should run the pump 24 hrs.
    Oct 2009
    3,899
    I think you're doing well! It just takes time to clear all the stuff out of a pool, no matter what kind of filter you have. Running the filter 24 hrs/day will help.
    You're not going to be able to tell if you pass the overnight test by running samples to the pool store. The only way to really do that is with a good test kit with a FAS-DPD test. Without that, just do your best to keep the pool at shock level, run the pump, and keep cleaning out your filter!
    22,537
    Quote Originally Posted by passionsrlz
    I hate to say it but you really need to order a good test kit. You really won't regret it once you use it a time or two. You can't do an overnight chlorine loss test using the pool store. You have to have the FAS-DPD chlorine test to perform it.
    Jun 2010
    Dayton, Ohio
    241
    should I just be running the filter or should I hook up the vacuum? I thought it seemed rather pointless because it just stirs it all up.
    and also I will have to bite the bullet and go get a good test kit. It wouldn't hurt to have one anyway.
    22,537
    As stuff collects on the floor use the vacuum, otherwise just let the pump run and it'll start to clear. As you've already learned, it takes a while sometimes.
    You'll need one to get your pool balanced once you're done shocking anyway. Take a look at the ones linked in my sig, they're the best bang for the buck.
  20. Back To Top    #20
    Jun 2010
    Dayton, Ohio
    241
    thank you for your advice. I will look into test kit and keep you guys posted.
