Results 1 to 17 of 17
Thread: Replace AGP top rail with deck board rather than going over?
    Titus's Avatar
    Jun 2010
    Nevada, TX
    47
    While thinking about deck designs, it occurred to me that you may be able to replace the top rail with deck board to create a seamless transition rather than going over it. A quick peak at my doughboy top rails show that they don't seem to provide any more structural support than a mounted deck board would, and a search of the internet turned up the picture below. Has anyone tried this? Can anyone think of a reason why this would be a bad idea?
    32x16 DoughBoy Autumn Breeze with partial bury, 7' deep end, happy bottom, and Access wedding cake steps.
    Pentair DE FNS Plus 48 with Pentair Challenger 1.5 hp.
    Order placed 6/13/10. Excavation started 6/15. First swim 6/18. Two thumbs up for DoughBoy, Crown Pools, and Mendez Pools and Decks.
    Re: Replace AGP top rail with deck board rather than going over?
    You would probably void any warranty.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Have y'all started your deck yet, or did I miss it somewhere? Looking forward to pics!
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I just built our deck flush with the top rail
    We are in the same predicament. I want the deck to go over our semi-buried pool because I don't want anyone stepping on the rail (You can remind kids a million times, but someone is bound to forget and then something gets bent) Has anyone just built the deck above the top railing? My husband's main concern is that our pool is buried except for about 15" on one and maybe 9-10 " on the far side. The backfilled circle is about 1 and 1/2 feet around the pool. It has been backfilled for about 3 weeks now, but he is worried about putting the deck foundation on the freshly backfilled area. We live in Florida, and the ground is the type of dirt that gets pretty hard after is has been saturated and then dried, but it isn't concrete for sure. Any thoughts?
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    ours is flush as well
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    We had a small deck built for our pool 6 years ago. We opted to have the edge of the deck sit just above the top 2 rails , so if a child wanted to jump into the pool, it would be a "clean" edge from deck to water. This past weekend we tore the old pool down, left the deck, and put the new same size pool up in the same location. Well, same size except 4" taller! We ended up having to jack the deck up 8" in order to get the new pool top rails to sit under the deck the way the old pool did.
    I'll post some pics tomorrow!
    Howell, NJ
    24'x52" Round AGP, j-hook liner, resin frame, 1 hp pump, sand filter, new fill well water (6/7/2011).
    14,600 gallons
    That's a pretty good idea although I would agree it would probably void the warranty. I've heard few warranties are honored due to homeowners getting creative with alterations. Also your going to be putting alot of stress on the side of the pool I would think with people stepping on them. Anyway I am currently designing a deck for our new above ground 24ft round. I am considering running my deck up over the top rails of the pool to keep feet off the top rails and just leave a gap for the cover. Most of the pools I've looked at folks run the deck boards under the top rails and I can't figure out why. My top rails are resin but being realistic..years of people stepping on them and they are bound to crack and of course by that time they will be difficult to replace with a matching product. Anyone's insight would be appreciated.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    We put ours under the rails. Word of caution: be sure to leave ample room for ground heave. We only had heave in one small section, but it definitely pushed up and now the boards in that area are flush, with no room to give.
    As for stepping on the rails, we issue one warning and then they're out!
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I just had my deck built and the contractor talked me into going over the top rail, I had wanted to go under the rail. I am happy with the outcome. (For some reason, the pic will not attach, sorry) The deck shows briefly at the end of this short video. http://www.youtube.com/watch?v=aEwu5YdM3eQ
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    I am thinking of replacing the resin top rail(s) with deck board. I would design the deck so the new deck rail does not have to take much weight: The deck would not rest on the pool except the one deck board. As the deck board has less flex than resin, it seems it would be stronger and better able to take normal standing and jumping forces.
    I don't like a deck that comes to the bottom of the rail because the rail looks like a trip hazard.
    A deck that goes over the rail puts the deck a long way away from the water. (I usually don't use a ladder, just jump or lift myself out.)
    A deck level with the rail would be OK, but my rails are not flat, so there are pinch points and trip hazards.
    I plan to use the resin rail as a hole template.
    Backyard Leisure Pools Venture 18' X 33'.
    Didn't like installer. Not liking manufacturer. :(
    Love TFP :)
    Can someone post pictures of the top rail replacement they completed using deck boards (composite would be my choice). I cannot view the picture Titus posted. It sure seems to be the way to go and I agree it should be much sturdier than the resin top cap. I then plan to bring the deck itself level with the deck board top rail thinking it will look as if they are all part of the deck. Anyone with suggestions or pictures would be greatly appreciated. I have a Sharkline 12X24 pool with aluminum sides that I placed in the ground 3' on one 24' side down to 1' on the other 24' side. I plan on using a 13:1 mix of sand to cement backfill as recommended by Doughboy and would like some input so I might direct my contractor on what I want to do. Thanks
    Pfeazel
    pfeazel,
    I have replaced the resin top rail with 2X6 treated pine and like the results. I will post some photos when I get a chance. I have not completed the whole deck, but so far I am happy with the results.
    Since composite decking is usually 1 inch thick, I think it would look and 'feel' even better than treated wood.
    The resin top rail extends below the top of the side wall. The wood does not. It only sits on top, so some of the side wall bracket is exposed.
    I did find that the pool does not have nice, consistent angles (or straights), so each piece has to be cut to fit. It takes a while to do, but it does look great.
    Love TFP :)
    I found that the manufacturer of my pool ladder (Confer) makes a conversion kit to go from over the wall, A-frame type ladder to one that mounts to the deck. Saved buying a whole new ladder. Don't have it installed yet, so not sure how well it works.
    Love TFP :)
    Have a look at this pool: http://hugues0509.skyrock.com/2.html
    Very nice deck.
    Buried oval above ground pool, 12x24, 7000gal
    Using the BBB method
    Sand filter 45kg, Pump 1000gph.
    Living in Portugal, Europe.
    Here are some pics of my incomplete deck.
    Love TFP :)
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I built my high deck just under the top seat. Here is a side shot to give you an idea of how much room there is, I have built a section for the kids to jump off of that goes over the top seat. I don't have photos of that right now.
    -- Guy --
